Anet A8 Plus 3d Printer Not printing in the Center
Posted by EzyMan
December 20, 2019 02:56AM
Hello Guys,
i ordered this printer Anet A8 3d Printer (300*300*350mm) and i assemble it and its extremly hard started from 16:00PM till 22:45PM xDDD but i did it <3
I wanted to make test print XYZ 20mm Calibration Cube but its not printing in the center, its print at the end of the corner.
also i checked Cura Program But Anet Printers not included their so i add it and i changed only the X, Y, Z dimensions, diameter 1.75 and Nozzle diameter.
Do i need to change something else to make it print in the Center?
Second question: If i want to flash this printer since i have this two parts:"USBASP USBISP AVR programmer USB ISP USB ASP ATMEGA8 ATMEGA128 and 10 Pin To 6 Pin Adapter Board Connector For ISP Interface Converter AVR AVRISP USBASP STK500 Standard
Does any1 can support me on this?
Wish you all the best.
Thanks
Edited 1 time(s). Last edit at 12/20/2019 02:56AM by EzyMan.
Re: Anet A8 Plus 3d Printer Not printing in the Center
January 26, 2020 06:34AM
Hello,
i use that in my Cura as Start-Code:
21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
M117 Bett aufheizen
M140 S50
M190 S0
G28
M190 S50
M104 S200
;G29
G0 X0 Y15 F9000 ; Go to front
;G0 Z0.15 ; Drop to bed
G92 E0 ; zero the extruded length
G1 X40 E25 F500 ; Extrude 25mm of filament in a 4cm line
G1 E-1 F500 ; Retract a little
G1 X80 F4000 ; Quickly wipe away from the filament line
G1 Z0.15 ; Raise and begin printing.
EX: Velleman K8200, nun Anet 8 Plus
