Problem: Simplify3D fill out tube model
Posted by RowdyN
January 20, 2020 04:19AM
Good morning,
I've a problem with my slicing program Simplify3D. I created a tube model with hexagon pattern on the outside with the model program Fusion 360.
But during the export from F360 to Simplify something bad happens. The slicing program fill out the tube without any reason for.
I never had this situation before and no idea to fix it. Are there any possible solutions?
Greetings
open | download - bild f360.jpg (474.9 KB)
open | download - bild simplify3D.jpg (295.5 KB)
Re: Problem: Simplify3D fill out tube model
January 28, 2020 03:52AM
There is a setting in the slicer that makes models solid, useful if you have a bad mesh. It's a simple tick box but can't remember off top of my head what it's called
January 28, 2020 01:06PM
Does your wall have thickness? S3D may be calling this a solid object if it is only a surface without a wall thickness.
Not enough information to say for certain what is happening.
DLC
Kits: He3D K200 Kossel, Folgertech Kossel 2020 upgraded E3Dv6, Anet A8 upgraded E3Dv6, Tevo Tarantula enhanced parts and dual-head
Scratch: Large bed Cartesian, Linear slide Delta, Maker-Beam XL Micro Delta
