Is it still worth it to build? February 08, 2020 04:22PM |
Re: Is it still worth it to build? February 08, 2020 04:51PM |
Re: Is it still worth it to build? February 19, 2020 02:40AM |
Re: Is it still worth it to build? February 19, 2020 02:48AM |
Admin Registered: 14 years ago Posts: 7,289 |
Re: Is it still worth it to build? February 20, 2020 05:04AM |
Re: Is it still worth it to build? February 20, 2020 10:35AM |
Re: Is it still worth it to build? February 20, 2020 10:59AM |
Re: Is it still worth it to build? February 20, 2020 12:42PM |
Re: Is it still worth it to build? February 22, 2020 03:06PM |
Re: Is it still worth it to build? February 24, 2020 10:16PM |
I've had three cnc machines, two of which I built, the last being completely my own.|
Re: Is it still worth it to build? February 26, 2020 09:43AM |
Re: Is it still worth it to build? February 27, 2020 08:46AM |
Re: Is it still worth it to build? February 28, 2020 10:45AM |
Re: Is it still worth it to build? March 02, 2020 01:44PM |
Re: Is it still worth it to build? March 02, 2020 02:45PM |
Simple bearing for radial support topped with a lock collar. For the triple screw, that should be more than fine. For the cantilever, it's a larger 10mm screw with a larger radial bearing topped with a thrust washer and lock collar.Quote
newbob
How is the roller shaft supported on the bottom end?
Thank you, but I don't put out incomplete and unbuilt designs.Quote
Alain60
Hello,
I like the design of your 3D printer as shown in the attachments. Is there any more documentation on it ?
That's the goal.Quote
chriske
Designed and built my own, never regretted it.
I make near perfect prints with it. Meanwhile a few friends copied my design and are very happy with it.
Re: Is it still worth it to build? March 17, 2020 05:15PM |
