Z Wobble, or is it? February 12, 2020 02:26PM |
Re: Z Wobble, or is it? February 12, 2020 05:35PM |
Re: Z Wobble, or is it? February 12, 2020 07:03PM |
Re: Z Wobble, or is it? February 12, 2020 08:57PM |
Re: Z Wobble, or is it? February 12, 2020 09:19PM |
Re: Z Wobble, or is it? February 12, 2020 09:37PM |
Re: Z Wobble, or is it? February 12, 2020 09:44PM |
Re: Z Wobble, or is it? February 12, 2020 09:59PM |
Re: Z Wobble, or is it? February 12, 2020 10:09PM |
Re: Z Wobble, or is it? February 12, 2020 10:10PM |
I am using these [cdn3.volusion.com] Yeah, I realized what TDD was finally.Quote
mcdanlj
TDD == the_digital_dentist
The pillow blocks I'm talking about have set screws (grub screws) to hold the lead screw, and the lead screw would never touch the riser. I have no recollection where I bought them, but [www.amazon.com] is an example of the kind of pillow block I'm talking about. Wouldn't damage a riser block on which it was mounted in any way.
I put pillow blocks like that at the top of the lead screw as well; theoretically overconstrained, but the 500mm T8 would whip when the bed was near the bottom so in practice it helped. YMMV.
Re: Z Wobble, or is it? February 13, 2020 07:42AM |
Re: Z Wobble, or is it? February 13, 2020 09:27AM |
Nope, it is a repeating pattern typical of Z Banding and there is just nothing I can do, short of having a CNC machine at my disposal which I don't have, to fix this. Just something I will have to live with and sand off if needed.Quote
MCcarman
Looks like a shrinkage effect to me.
If it was it would be affected by temperature variation - you think nothing has changed there. Note that cooling fan influence may be more relevant to bang - bang so changing the cooling fan settings may have an influence.
Layer print time. It is on the small cube but may not be the same on larger objects. Hmmm - cooling fan on for small layers ?
Infill effects - if you had different infill layers.
Can't really see the sides of the cone so can't judge it. If it is a layer size effect then it would be more pronounced near the cone top.
Re: Z Wobble, or is it? February 13, 2020 11:23AM |
Re: Z Wobble, or is it? February 13, 2020 12:39PM |
Re: Z Wobble, or is it? February 13, 2020 05:42PM |
Re: Z Wobble, or is it? February 13, 2020 06:50PM |
Re: Z Wobble, or is it? February 14, 2020 07:39AM |
Re: Z Wobble, or is it? February 14, 2020 08:04AM |
* The PID frequency will be the same as the extruder PWM. * If PID_dT is the default, and correct for the hardware/configuration, that means 7.689Hz,
Re: Z Wobble, or is it? February 14, 2020 12:27PM |
Re: Z Wobble, or is it? February 14, 2020 01:01PM |
It's been years since I used Marlin, but IRIC there are variables somewhere that set the PWM frequencies for the bed and hot-end independently, and they default to hundreds or thousands of Hz.
Re: Z Wobble, or is it? February 14, 2020 01:05PM |
Yes, BUT is that 7hz for the LPC 1768 as well? Something tells me it isn't due to it running at 100mhz vs 16mhz.Quote
MMcLure
At least in recent Marlin this isn't true - the default bed and hot end PWM frequency is around 7Hz, unless you change the setting of SOFT_PWM_SCALE.
Re: Z Wobble, or is it? February 14, 2020 11:33PM |
Dark Alchemist
Re: Z Wobble, or is it? February 15, 2020 01:36AM |
Re: Z Wobble, or is it? February 18, 2020 01:17PM |
Dark Alchemist
edit: Oh, the red led never flickers it is full on or full off and it doesn't flicker even on a smart phone camera.
Re: Z Wobble, or is it? February 18, 2020 05:51PM |
