Heatbed issues February 14, 2020 02:24AM |
Re: Heatbed issues February 14, 2020 07:02AM |
Re: Heatbed issues February 14, 2020 08:21AM |
Re: Heatbed issues February 14, 2020 08:51AM |
Re: Heatbed issues February 14, 2020 12:21PM |
Re: Heatbed issues February 14, 2020 01:45PM |
Re: Heatbed issues February 15, 2020 05:27AM |
Re: Heatbed issues February 15, 2020 06:41AM |
Re: Heatbed issues February 15, 2020 10:32AM |
Re: Heatbed issues February 15, 2020 10:57AM |
Re: Heatbed issues February 15, 2020 12:31PM |
Re: Heatbed issues February 15, 2020 12:51PM |
Re: Heatbed issues February 15, 2020 02:12PM |
the_digital_dentist
But not just any aluminum plate. "Normal" plate is rolled or extruded and not very flat. Cast tooling plate is best because it comes milled flat on both sides.
Re: Heatbed issues February 15, 2020 03:14PM |
mcdanlj
the_digital_dentist
Not only that, but also—even if you mill rolled plate flat to the same precision as cast plate, the rolled plate still tends to warp when heated due to internal stresses, whereas cast plate does not.
Re: Heatbed issues February 16, 2020 12:54AM |
Re: Heatbed issues February 16, 2020 07:05AM |
Re: Heatbed issues February 16, 2020 07:06AM |
Re: Heatbed issues February 16, 2020 07:59AM |
Re: Heatbed issues February 17, 2020 01:20PM |
leadinglights
mcdanlj
There is a great difference between believing that something won't work and trying it out. I was informed by several people on this forum that 0.25mm thick PTFE over nichrome wire would be too thermally insulating. I did the maths and then tried it out and it was good. If you have tried something and have knowledge that it won't work then say so. If you think that something won't work then say that you think it won't work.
