Ballscrew v Lead Screw for Small Printer
Posted by Doppler9000
March 25, 2020 07:05PM
I am planning out a printer, probably corexy, that will be built around a 150mm to 200mm square bed.
I have seen some nice, unused, shortish ballscrews on eBay at attractive prices.
There are some 16mm diameter Hiwins, for example.
There was conflicting advice in prior posts, so I am reasking.
I am assuming the ballscrew will be straighter and more rigid, and can be moved faster.
Since the build is small, I was hoping to get the simplicity advantages of a cantilevered bed, using the screw and a linear rail. At the prices, going with two would be fine, if there is a performance advantage.
There will be more rotational mass, but I was thinking that the small moment makes that a secondary issue.
Any thoughts?
Re: Ballscrew v Lead Screw for Small Printer
March 25, 2020 09:48PM
Ball screw lead may not be appropriate for Z axis...
Son of MegaMax 3D printer: [www.instructables.com]
March 25, 2020 10:42PM
1605 — 16mm diameter, 5mm lead — is common. So is 1204 — 12mm diameter, 4mm lead. 4mm lead is the same as two-start trapezoidal. I know quad-start 8mm lead and single-start 2mm lead are the most common options, but 4mm is fine too.
March 25, 2020 10:58PM
the_digital_dentist
I saw references to people using ~3:1 cog diameter ratios, to overcome some of the potential lead issues, but I am not sure where the limits lie.
Assuming the lead works, any downsides to the ballscrew?
Edited 2 time(s). Last edit at 03/25/2020 11:42PM by Doppler9000.
March 25, 2020 11:41PM
mcdanlj
With a 5mm lead, a 200 steps/revolution stepper gives 0.025mm/turn in full steps, 0.00156mm/turn @ 1/16 microsteps.
Obvious any gear ratio could make these smaller.
I assume this is enough resolution for Z movements?
