Moving from 12v to 24v question
Posted by roontoon
April 06, 2020 04:35PM
I am thinking of moving from 12v to 24v. I am using a Bigtreetech SKR v1.3 which can be used with 24 volts. Will the rest of the components, 2209 drivers, stepper motors, and bed be used with 24 volts? Thanks.
Re: Moving from 12v to 24v question
April 06, 2020 08:03PM
Most will work with either 12 or 24 volt supplies.
You should be careful with the cooling fans most likely 12V the Hot-Bed ? could be 12V or 12/14 volt the Hot-end heaters 12V and not sure about on the 2209 drivers.
RepRap Forum am I missing anything.
April 06, 2020 08:47PM
My main issue is that I have a 300x300 mm bed that will not go above 66C. I am currently using a server power supply that is 12v/52amps.
