Re: Printer won't print June 24, 2011 11:47PM |
G21 ;set units to millimeters
M104 S225.0
M108 S10.59
G1 X-9.46 Y-3.23 Z0.4 F857.637
M101
G1 X-9.44 Y-3.33 Z0.4 F485.9943 E0.1402
G1 X-9.3 Y-3.41 Z0.4 F485.9943 E0.2122
G1 X-9.23 Y-3.87 Z0.4 F485.9943 E0.6085
G1 X-9.08 Y-3.99 Z0.4 F485.9943 E0.2524
G1 X-8.97 Y-4.32 Z0.4 F485.9943 E0.4562
G1 X-8.89 Y-4.44 Z0.4 F728.9915 E0.124
G1 X-8.77 Y-4.53 Z0.4 F485.9943 E0.1968
G1 X-8.67 Y-4.7 Z0.4 F485.9943 E0.2587
G1 X-8.67 Y-4.85 Z0.4 F485.9943 E0.1919
G1 X-8.64 Y-4.98 Z0.4 F728.9915 E0.1218
G1 X-8.28 Y-5.51 Z0.4 F485.9943 E0.8387
G1 X-8.14 Y-5.63 Z0.4 F728.9915 E0.157
G1 X-7.98 Y-5.72 Z0.4 F485.9943 E0.2431
G1 X-7.86 Y-5.87 Z0.4 F485.9943 E0.2578
G1 X-7.82 Y-6.05 Z0.4 F485.9943 E0.2412
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Printer won't print June 25, 2011 08:27PM |
Re: Printer won't print June 25, 2011 08:42PM |
Re: Printer won't print June 25, 2011 08:50PM |
Re: Printer won't print June 26, 2011 03:39PM |
Re: Printer won't print June 26, 2011 03:58PM |
Re: Printer won't print June 26, 2011 04:05PM |
Re: Printer won't print June 26, 2011 04:18PM |
Re: Printer won't print June 26, 2011 04:22PM |
Re: Printer won't print June 26, 2011 04:27PM |
Re: Printer won't print June 26, 2011 04:33PM |
Re: Printer won't print June 26, 2011 05:10PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Printer won't print June 26, 2011 05:13PM |
Re: Printer won't print June 26, 2011 06:32PM |
Re: Printer won't print June 26, 2011 06:54PM |
Re: Printer won't print June 26, 2011 06:58PM |
Re: Printer won't print June 26, 2011 07:35PM |
Re: Printer won't print June 26, 2011 08:51PM |
Re: Printer won't print June 26, 2011 09:07PM |
Re: Printer won't print June 26, 2011 09:15PM |
Re: Printer won't print June 26, 2011 10:08PM |
Sublime
Second yes it does come to a complete stop after every single line. Sprinter does have a constant minimum to deal with this problem.
Third I can print curves at 120mm/s without a single hiccup from communications ( check my videos ) so your issues at 20mm/s are either a host issue or Sprinter issue not USB.
Re: Printer won't print June 26, 2011 10:40PM |
Re: Printer won't print June 27, 2011 03:04AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Printer won't print June 27, 2011 12:06PM |
Re: Printer won't print June 27, 2011 05:45PM |
Re: Printer won't print June 27, 2011 06:16PM |
Re: Printer won't print June 28, 2011 03:15PM |
I tried teacups retract and skeinforges but both take far to long even at 4000mm/s
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Printer won't print June 28, 2011 04:29PM |
Re: Printer won't print July 03, 2011 03:07PM |
Re: Printer won't print July 03, 2011 03:12PM |
