T8-8 or T8-2 which lead screw should I get? May 02, 2020 06:48PM |
Re: T8-8 or T8-2 which lead screw should I get? May 02, 2020 09:04PM |
Re: T8-8 or T8-2 which lead screw should I get? May 02, 2020 09:16PM |
Re: T8-8 or T8-2 which lead screw should I get? May 03, 2020 07:02AM |
#define RESTORE_LEVELING_AFTER_G28
* Default Axis Steps Per Unit (steps/mm)
* Override with M92
* X, Y, Z, E0 [, E1[, E2...]]
// Typical stepper motors have 200 steps per full step/rev = 1.8°/step, so 1/16 microstepping = STEPS_PER_REVOLUTION_E = 3200
// X-Y Axis 3200, / 20 tooth, / 2mm pitch = 200*16 / 20 / 2 = 80 :: (STEPS_PER_REVOLUTION_X / IDLER_TEETH_X / BELT_PITCH_X)
// Z Axis 3200, / 1.25mm pitch leadscrew = 200*16 /1.25 = 2560 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 8mm pitch leadscrew = 200*16 /8 = 400 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 4mm pitch leadscrew = 200*16 /4 = 800 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 2mm pitch leadscrew = 200*16 /2 = 1600 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// E-Axia 3200, / (11mm Gear OD * pi) :: (STEPS_PER_REVOLUTION_E * EXTRUDER_GEAR_RATIO / (PINCH_WHEEL_DIAMETER * PI))
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 1600, 94.4962144 }
#define DEFAULT_MAX_FEEDRATE { 250, 250, 5, 25 }
//#define LIMITED_MAX_FR_EDITING // Limit edit via M203 or LCD to DEFAULT_MAX_FEEDRATE * 2
#if ENABLED(LIMITED_MAX_FR_EDITING)
#define MAX_FEEDRATE_EDIT_VALUES { 600, 600, 10, 50 } // ...or, set your own edit limits
#endif
#define DEFAULT_MAX_ACCELERATION { 3000, 3000, 100, 10000 }
//#define LIMITED_MAX_ACCEL_EDITING // Limit edit via M201 or LCD to DEFAULT_MAX_ACCELERATION * 2
#if ENABLED(LIMITED_MAX_ACCEL_EDITING)
#define MAX_ACCEL_EDIT_VALUES { 6000, 6000, 200, 20000 } // ...or, set your own edit limits
#endif
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration for travel (non printing) moves
Re: T8-8 or T8-2 which lead screw should I get? May 03, 2020 07:42AM |
Re: T8-8 or T8-2 which lead screw should I get? May 03, 2020 01:51PM |
// Z Axis 3200, / 8mm pitch leadscrew = 200*16 /8 = 400 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD) // Z Axis 3200, / 2mm pitch leadscrew = 200*16 /2 = 1600 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)It also means the Z-Axis stepper motors will have to work less to lift the Z-Axis load.
Re: T8-8 or T8-2 which lead screw should I get? May 08, 2020 03:09AM |
Re: T8-8 or T8-2 which lead screw should I get? May 08, 2020 03:24AM |
Re: T8-8 or T8-2 which lead screw should I get? May 08, 2020 05:21AM |
Re: T8-8 or T8-2 which lead screw should I get? May 08, 2020 07:59AM |
etfrench
They also make T8-1 lead screws
MKSA
It will give enough torque to straighten any crooked frame and overcome stubborn guidesA must for most hobby 3D printer.
A good machine will prefer an 8mm pitch.
Re: T8-8 or T8-2 which lead screw should I get? May 08, 2020 08:36AM |
Re: T8-8 or T8-2 which lead screw should I get? May 08, 2020 08:47AM |
witor
Why a good machine will prefer a 8mm pitch?
Re: T8-8 or T8-2 which lead screw should I get? May 22, 2020 01:16PM |
Re: T8-8 or T8-2 which lead screw should I get? May 23, 2020 01:59AM |
Re: T8-8 or T8-2 which lead screw should I get? May 23, 2020 06:26AM |
Re: T8-8 or T8-2 which lead screw should I get? May 23, 2020 07:36AM |
Re: T8-8 or T8-2 which lead screw should I get? May 23, 2020 09:33AM |
Re: T8-8 or T8-2 which lead screw should I get? May 24, 2020 07:31AM |
Re: T8-8 or T8-2 which lead screw should I get? May 24, 2020 01:47PM |
Re: T8-8 or T8-2 which lead screw should I get? May 24, 2020 09:53PM |
Re: T8-8 or T8-2 which lead screw should I get? May 25, 2020 06:44AM |
Re: T8-8 or T8-2 which lead screw should I get? May 26, 2020 10:40AM |
