Hello everyone !
I'm working on my own design 3D printer and I have an end stop problem that I can't fix.
My 3D printer like Prusa i3 Model. 2 motor control the Z axis, Heated Bed on the Y axis and extruder on the X axis
Y axis endstop always open. When I home to Y axis it continues to moving and it causes terrible noise and mechanical compulsion.
NOTES
I check the cable connection many times, its OK
Endstops plugged into the min sections on RAMPS boad.
Endstop is not broken, it is working (i tryed).
I change the RAMPS, nothing changed.
The endstop positions is correct (minimum positions of axises)
Motor directions is correct. (Moving throughout to min position when I moved manually)
I'm using Repetier Host to manual control.
INFORMATIONS
Boards : ATMega 2560 CH340 & RAMPS 1.4
Step Motor Drivers : A4988
End Stop Type
My Firmware : I used a marlin fimware. I'm new about this so i don't know very well the codes.
Here is my M119 commands..
Free Position ----------------
Pressing X endstop-------------------
Pressing Y endstop------------
Pressing Z endstop
Xendstop OPEN --------------
Xendstop TRIGGERED --------------
Xendstop OPEN -----------------
Xendstop OPEN
Yendstop OPEN --------------
Yendstop OPEN ------------------------
Yendstop OPEN
Zendstop OPEN --------------
Zendstop OPEN ------------------------
Zendstop TRIGGERED
My End Stop settings in configuration.h file
//============================== Endstop Settings ===========================
// @section homing
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
//#define USE_ZMAX_PLUG
// Enable pullup for all endstops to prevent a floating state
#define ENDSTOPPULLUPS
#if DISABLED(ENDSTOPPULLUPS)
// Disable ENDSTOPPULLUPS to set pullups individually
//#define ENDSTOPPULLUP_XMAX
//#define ENDSTOPPULLUP_YMAX
//#define ENDSTOPPULLUP_ZMAX
//#define ENDSTOPPULLUP_XMIN
//#define ENDSTOPPULLUP_YMIN
//#define ENDSTOPPULLUP_ZMIN
//#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
// Enable pulldown for all endstops to prevent a floating state
//#define ENDSTOPPULLDOWNS
#if DISABLED(ENDSTOPPULLDOWNS)
// Disable ENDSTOPPULLDOWNS to set pulldowns individually
//#define ENDSTOPPULLDOWN_XMAX
//#define ENDSTOPPULLDOWN_YMAX
//#define ENDSTOPPULLDOWN_ZMAX
//#define ENDSTOPPULLDOWN_XMIN
//#define ENDSTOPPULLDOWN_YMIN
//#define ENDSTOPPULLDOWN_ZMIN
//#define ENDSTOPPULLDOWN_ZMIN_PROBE
#endif
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
#define X_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // Set to true to invert the logic of the probe.
