MK8 Plated A2 Tool Steel Wear Resistant Nozzle - Causing warping? May 09, 2020 09:03PM |
Re: MK8 Plated A2 Tool Steel Wear Resistant Nozzle - Causing warping? May 11, 2020 08:45AM |
Re: MK8 Plated A2 Tool Steel Wear Resistant Nozzle - Causing warping? May 11, 2020 09:10AM |
Re: MK8 Plated A2 Tool Steel Wear Resistant Nozzle - Causing warping? May 11, 2020 09:39AM |
Re: MK8 Plated A2 Tool Steel Wear Resistant Nozzle - Causing warping? May 11, 2020 10:29AM |
PDBeal
The prints have no issues sticking to the bed, the problem is they are not staying stuck to the bed through the course of the print when using the wear resistant nozzle.
Re: MK8 Plated A2 Tool Steel Wear Resistant Nozzle - Causing warping? May 11, 2020 11:37AM |
the_digital_dentist
OK, you normally print the first layer slower than the others. But you're having a problem with the print letting go when you use that steel nozzle. So try reducing the speed (even more) in order to get that first layer to stick throughout the print.
