Why don't we use better Heat sinks? May 31, 2020 07:58AM |
Re: Why don't we use better Heat sinks? May 31, 2020 10:01AM |
Re: Why don't we use better Heat sinks? May 31, 2020 10:07AM |
Re: Why don't we use better Heat sinks? May 31, 2020 10:14AM |
Re: Why don't we use better Heat sinks? May 31, 2020 11:05AM |
Re: Why don't we use better Heat sinks? May 31, 2020 12:41PM |
Re: Why don't we use better Heat sinks? May 31, 2020 04:32PM |
MKSA
And why a separate heatsink ? Why not use it as the base of the extruder on which to mount the hobbedgear plus idelr and motor that will be cooled at the same time ?
I use half of this: [www.banggood.com]
MKSA
An other problem of this kind of heatsink is its height. It adds more than 25 mm to the distance from the hobbgear and the nozzle tip. A flat easily available Al heatsink like I use just adds 10mm.
Dust
Overkill, and if made from copper expensive.
leadinglights
I know very little about skiving as a machining process so won't comment on that. I will, however, comment on the use of copper in this otherwise very interesting design. I feel I am able to give some input in this as I have prototyped a few heatsinks and hotends with different materials.
While the thermal conductivity of aluminium is only about 60% of the thermal conductivity of copper, the demand on a heatsink is to transmit heat from a source which will likely be less than 100°C to the air at say 20°C. For this purpose, the difference between aluminium and copper is not very significant. By comparison, the density of copper is about 3 times that of aluminium and is very significant if the moving mass of the heatsink is important - as it usually will be.
The machinability of pure copper and aluminium are both poor, particularly in their annealed state, but easily machinable aluminium alloys usually retain more of their thermal conductivity than equivalent copper alloys. Brass, for example, can have as little as 6.5% of the conductivity of copper while 6061 Aluminium alloy has >80% of the thermal conductivity of pure aluminium.
The situation on a hotend heater block is somewhat different as there will be no fragile fins and the increased conductivity of copper at the higher temperatures allows the heater block to be smaller. An additional advantage of using copper for the heater block is that the ca 50% higher specific heat of copper creates a reservoir for sudden demands for heat.
Re: Why don't we use better Heat sinks? June 01, 2020 01:41AM |
Origamib
I do agree with you on copper vs. Alu. I discovered the density issue about 10 minutes after making this post! The above heat sink would weigh in at 150 grams, but a slight redesign later (10mm slimmer) and it now weighs 27g if made in Aluminium or 90g in copper (compared to 18g for the round E3D heat sink). I chose copper in this render because its purdy, but realistically aluminium is the way to go.
Re: Why don't we use better Heat sinks? June 01, 2020 09:35AM |
Re: Why don't we use better Heat sinks? June 04, 2020 04:36PM |
Re: Why don't we use better Heat sinks? June 05, 2020 02:32AM |
Re: Why don't we use better Heat sinks? June 05, 2020 06:37AM |
