Printing with Raise3D Pro2 June 03, 2020 08:03PM |
Re: Printing with Raise3D Pro2 June 03, 2020 10:38PM |
After you unpacked the 3D printer successfully and completed the initial hardware setup, you install Raise3D’s own slicer software ideaMaker. The ideaMaker installation is not difficult and also step-by-step described in the quick start guide.
The only thing you need to do now is loading the filament in the 3D printer. This is done by following the instructions on the machine control. When the filament is loaded, you can start the first print job and away you go.
Ones you have a model ready for printing in ideaMaker, you press ‘start’ and a new screen with your template options opens. In these templates you can adjust everything like layer height, speeds, infill options, adhesion options, etc. Here you can use Raise3D’s standard printing templates or you can make and save new templates with your own settings.
When you prefer to use Simplify3D as slicer software instead of ideaMaker, you will need an FFF profile of the Pro2. This profile is not yet available in Simplify3D or on their website. We have it available, let us know if you want it and we’ll send you the profile.
Re: Printing with Raise3D Pro2 June 03, 2020 10:57PM |
Re: Printing with Raise3D Pro2 June 04, 2020 05:34AM |
Re: Printing with Raise3D Pro2 June 04, 2020 04:34PM |
Re: Printing with Raise3D Pro2 June 04, 2020 09:28PM |
Are you recommending it and if so please send me the profile? I am not biased towards any particular slicer I just want one which works well and consistently with my Pro2.Quote
Re: Printing with Raise3D Pro2 June 05, 2020 12:32AM |
Vagulus
Checking the gCode for a print (I am no expert in gCode) I found no 'T1' command. In inserted a 'T0' into the startup code and the model printed with the Left Extruder as it should. N.B.: I made sure that the 'T1' command was not countermanded further down the code.
My printer works okay with ideaMaker but it is the most puzzling piece of software I have ever come across (and I have marked University Student programs ).
Re: Printing with Raise3D Pro2 June 05, 2020 12:48AM |
Re: Printing with Raise3D Pro2 March 28, 2021 08:17PM |
Re: Printing with Raise3D Pro2 April 12, 2021 11:29PM |
Re: Printing with Raise3D Pro2 April 13, 2021 12:22AM |
Re: Printing with Raise3D Pro2 April 13, 2021 02:38AM |
Re: Printing with Raise3D Pro2 April 13, 2021 06:21PM |
