Failed print layer synchronized time lapse
June 24, 2020 11:10PM
[vimeo.com]
26 hours into a 36 hour print...
Son of MegaMax 3D printer: [www.instructables.com]
Re: Failed print layer synchronized time lapse
June 25, 2020 06:09PM
It looks good from what I can see. How is it a failure?
June 25, 2020 06:45PM
It's supposed to be almost 600 mm tall - I think there was a power glitch due to a thunderstorm that caused the controller to kill the print.
It's still useful for something, just not what it was intended to be used for- a lamp.
June 26, 2020 08:03AM
I've had that happen a few times but never that long into a print. That's quite upsetting.
After the 3rd time I bought a refurbished UPS from the Micro Center. I calculated it should keep the printer running for 9 or 10 minutes more in the event of a power failure. It helped a couple of times for some momentary drop outs.
June 26, 2020 10:03AM
It turns out there's some other problem. I reran the print and this time is got to 343 mm and failed, reporting heater fault again. I'll tear into it this weekend and figure out what the real problem is.
