Reviving a Makerbot Replicator 2X June 27, 2020 05:24PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Reviving a Makerbot Replicator 2X July 11, 2020 05:25AM |
Re: Reviving a Makerbot Replicator 2X July 11, 2020 05:36AM |
Admin Registered: 18 years ago Posts: 14,179 |
Re: Reviving a Makerbot Replicator 2X July 11, 2020 05:52AM |
VDX
... you can modify a 5v-optocoupler for 24V with a resistor of 1k9 when it needs 10mA ... or a higher value for lower working current
Re: Reviving a Makerbot Replicator 2X July 11, 2020 09:37AM |
Re: Reviving a Makerbot Replicator 2X July 11, 2020 05:22PM |
VDX
... yes - if you have the shematics/datasheet for a 5V part, then simply check for the current you'll need and calculate the resistor by:
24V - 5V = 19V
e.g. -- needed current for operation = 2mA ==> then for resistor (R=U/I): R = 19V/0,002A => 9k5 (or even better 10k, what's a standard value) ...
Re: Reviving a Makerbot Replicator 2X August 03, 2020 11:56AM |
Bilinear Leveling Grid:
0 1 2
0 -0.210 -0.012 -0.100
1 -0.220 +0.007 -0.172
2 -0.304 -0.137 -0.349
echo:busy: processing
0 1 2
0 -0.175 +0.025 -0.057
1 -0.195 +0.037 -0.130
2 -0.284 -0.115 -0.332
Re: Reviving a Makerbot Replicator 2X August 11, 2020 01:29PM |
Re: Reviving a Makerbot Replicator 2X August 11, 2020 02:13PM |
guru_florida
Congats! Coincidentally I just refurbished my Rep2X as well.
- BTT SKR 1.4 Turbo
- Trinamic TMC2209 stepper modules
- Dual Dragon Hotends
- E3D heaters/thermisters
- TFT 35 Touch screen
- BL Touch probe
I also had a lot of previous upgrades I kept:
- Bottleworks magnetic glass printing base
- Bottleworks alumninum arms
- better extruder tensioners (not sure where I got them)
Dragon hot-ends fit E3D nozzle dimensions, so I used this replacement carriage mount. Worked great, looks great, only issue is the plastic acts as a heat barrier between steppers and heat break bar and carriage which served as a heat sink as well so my extruder steppers will overheat and soften the filament until it jams. I've added small heatsinks to the top of the steppers and this has definately helped but I may need more. I have a CNC machine so am designing a custom heatsink that will go under the steppers and will also be cooled by the E3D fans. XYZ motors can take a heatsink on the back, but steppers cant on the back for clearance reasons but can on the top. Possibly we can replace the extruder steppers with a high performance pancake stepper and get clearance for heat sinks.
[www.thingiverse.com]
This machine is now sooo quiet! Lots of torque in the 2209s, more than the steppers can handle and not overheat. Printing first layers with the BL touch is easy! Dragon hotends are performing really well. Love it. Love Marlin and its many options. Rep2X IMO is a great frame to do a refurbish on.
Have you printed anything yet?
Re: Reviving a Makerbot Replicator 2X August 11, 2020 04:45PM |
Yes, it's exponential too, so 500mA should probably half the heat which is what I am running at now. It seems to be good. I think bowden-drive is a good decision except I am not sure how well it will work with ninja-flex which is something I want to do. Keep me posted on how you get along, all other things considered I think bowden it is the better way to go. Just for the heat dissipation reason!Quote
I have mounted heatsinks on all the stepper motors and probably have to lower the mA settings on the TMC2209's. I notice that with the standard setting of 800mA the motors get too hot.
Yes, it takes about 15mins to heat upQuote
Do you drive the 24v heated bed directly from the SKR 1.4? I have ordered a special heatbed MOSFET to take the strain off of the SKR 1.4 but to be honest, while doint some test prints, I noticed the SKR 1.4 can take the heated bed perfectly. And what about sensorless homing, do you use it?
but it works. I have my eyes on a large FET+heatsink but not a priority atm.No issues here, I can barely tell the fan is on but am am running at 220, not 255 so it makes a difference. I've always found the dual extrusion a PITA. Always seems 1 of the nozzles is not working or second nozzle lifts up the edge of a print. I considered dumping the second but I'm giving it one more go, I would really like to use 1 for dissolvable support.Quote
Also, I'm using an inductive probe instead of a BLtouch, sadly the nuts keeping the probe in place keep loosening up because the 24v fan on the E3D v6 is making so much noise and is causing a lot of hard vibration. This shakes loose the inductive probe so I'll have to fix it with cyanoacrylate I guess. I'll have to design a new bracket in which I add a custom tightening bolt with a nylon locknut to clamp around the probe and hold it that way. Also, eventually I want to design a smaller carriage as I'm not ready to start trying out dual-nozzle setups and am currently reusing the dual-setup X-carriage.
Slurry should work...or load some filament into dremel tool and rotate it into the part using friction welding....or use a soldering iron to cut a V into the crack and melt some new stuff in there. Im not sure what plastic those parts are made of though. Sacrifice the plastic from the spool holders in the back if you still have them....those are useless lolQuote
As far as prints go, I've only printed two hollow vases and a calibration box and then noticed there was something wrong with one of the interior ABS injection molded corner brackets. It was completely cracked in two!!! So I decided to make ABS slurry and glue the part with it and also strengthening it by adding more material and gluing on two small reinforcement parts. Makerbot didn't reply to my service request and I cannot register with the serial number of the machine for getting in touch with them to get a replacement. On top of that no shop in the world wanted to sell me the replacement part because they all only ship inside their own country because of nonsense reasons. So I had to fix it with ABS glue. Mounted it today but we are currently in a severe heatwave for over a week already so I am not able to start printing until somewhere next week I guess.
Do you mean the part that bolts onto the stepper? It probably didnt melt from the heated chamber but the stepper temp running at 800mA.Quote
Also, the extruder I created melted because it was in the heated chamber first.. So I ordered an aluminium one, this also has the added effect of not being able to use the compact style extruder for now. I wist the aluminium extruder replacements were still available, since they only take up half of the space on the motor face they are very flexible in use.
Just now. It's jamming and losing steps.
Re: Reviving a Makerbot Replicator 2X August 12, 2020 03:03AM |
guru_florida
Do you drive the 24v heated bed directly from the SKR 1.4? I have ordered a special heatbed MOSFET to take the strain off of the SKR 1.4 but to be honest, while doint some test prints, I noticed the SKR 1.4 can take the heated bed perfectly. And what about sensorless homing, do you use it?but it works. I have my eyes on a large FET+heatsink but not a priority atm.
OH man! I love the TMC cooling tunnel! I gotta print me one of those
Looks like I am having a new problem with my X railJust now. It's jamming and losing steps.
Re: Reviving a Makerbot Replicator 2X August 12, 2020 02:12PM |
Pure X moves smooth but has a dirty sound, Y has a vibration. Circles are really noisy and vibrating. Could be bearings, or could even be bad wiring....hard to tell yet. Strange I get a bunch of prints the last 2 weeks without issue.|
Re: Reviving a Makerbot Replicator 2X August 12, 2020 02:13PM |
Re: Reviving a Makerbot Replicator 2X August 15, 2020 07:33AM |
guru_florida
Heatbed: 15mins: 10 mins to 100degC, 15 to 110degC. Are you only heating to 100 maybe? I have a bottleworks heatbed and I think it added time....but much better than stock table was.
I am not sure what heatbed I have, it's a cast iron bed it seems. Not even all over, but definitely good enough. Today I converted the SKR 1.4 to use this MOSFET:Quote
I have 2 Trianglelabs hotends. I wouldnt exactly call them a clone, but a mix between the E3D and Mosquitto. I was contemplating E3D, which I am a big fan of their stuff, but wanted the stainless steel and no-teflon insert of the mosquitto type....but in a E3D mount. lol. Quality of the Trianglelabs seems very good. Heater, thermistor and nozzles are genuine E3D.
So far the 2209s barely go above room temp so I wont add a fan yet, but will if anything changes. Thanks for the offer! One word of caution, if your fan fails, which they always do, the tunnel will act to trap the heat and you won't even see it. Though the 2209s seem like they wont get hot anyway at 5-800mA.
I am using original sleeve bearings. I bought some LM8SUU from Fargo (good stuff) but they were terribly noisy and grindy and immediately went back. But I think there is something going on with these sleeves right now and they have to at least be taken off and cleaned. I already cleaned the shafts well. I might try the linear bearings again. I might try the Solid Polymer kind but I hear unless you compress fit them into the mount (not possible with our Rep 2x carriage) then the clearance is sloppy.
Fiddled with the machine for hours but I am *down* for the count atm.Pure X moves smooth but has a dirty sound, Y has a vibration. Circles are really noisy and vibrating. Could be bearings, or could even be bad wiring....hard to tell yet. Strange I get a bunch of prints the last 2 weeks without issue.
FYI I've been playing with the bed leveling. Thought my glass bed was a little unlevel, but now I think it may be the weight of the carriage is causing rail deflection in the center. Measured curve is convex and what you would expect with deflection. Not a big deal since Marlin measures and counter-acts it but thought you might see it too. Likely not as much since your Bowden carriage is probably one-fifth the weight of mine. It's max 0.3mm off, typically <0.15mm.
Posting my test GCode. It might come in handy for you to test movement. It simply does a bunch of perimeter moves, hourglass figures and circles at different speeds. Since you have a 2X bed and probably configured for the same [-125, -70, 125, 70] bed dimensions (original Rep2X coords with 0,0 centered in the bed middle).
Re: Reviving a Makerbot Replicator 2X August 18, 2020 02:55AM |
Re: Reviving a Makerbot Replicator 2X August 18, 2020 04:07PM |
Re: Reviving a Makerbot Replicator 2X August 18, 2020 04:41PM |
guru_florida
I am back on my feet! Dismantled the the XY assembly and cleaned all the rods. Put the rods in my drill and spun them while polishing them up and down with scotchbrite pads. Then cleaned with alcohol. Definitely the brass sleeves are running smoothly and will slide on their own with a little slope. Machine is working with less drag. However, I dont think that was my issue. In my startup script, I had put a G1 move then a low-current stepper command. The low-current stepper command was executing before the G1 was finished thus steppers lost steps. Had to add a 5sec delay before turning down steppers. (I turn down steppers while heating the bed/extruders.) Same with bed levelling now, I set heating to 110, wait 5 mins, then do ABL, then issue wait-for-stabilize command.
FYI. With further testing using my sample gcode above I am getting smooth motion except for the circles are a *bit* chatty. After a long goose chase it comes down to my Jan 2020 Marlin release and arcs being interpolated as N linear moves. Apparently there has been a number of G2/3 arc improvements in the last 6 months. What fw version are you on?
I like the MOSFET and window pane pushbuttons. I will definitely use those, thanks! I was looking at the same MOSFET but wasnt sure it will make a difference. Glad to see it does. I also just designed a TFT35 holder lol. I will post mine here as well in a moment, I am reprinting a part now.
I am using ABS material and not having an issue with melting warping so far.
Our SKR supports any neopixel strips. I just ordered one coming this Thursday. I didnt order the BTT regulator but instead use an adjustable DROK. I am a big fan of the DROK stuff:
[www.amazon.com]
This one is also awesome for testing projects: [www.amazon.com]
Re: Reviving a Makerbot Replicator 2X August 20, 2020 08:53PM |
Feedrate
M203 X500.00 Y500.00 Z10.00 E30.00
Maximum Acceleration (units/s2):
M201 X500.00 Y500.00 Z100.00 E5000.00
Acceleration (units/s2): P R T
M204 P3000.00 R3000.00 T3000.00
Advanced: B S T J
M205 B20000.00 S0.00 T0.00 J0.01
Re: Reviving a Makerbot Replicator 2X August 21, 2020 03:03AM |
Re: Reviving a Makerbot Replicator 2X August 23, 2020 02:37PM |
Since you did the extrusion calibration, I can only surmise it might be just layers printing too fast. Maybe try a larger part? You seem to be more knowledgeable in printing than I am so take any my advice with a grain of salt. I've been doing 3D printing since ~2014 but not consistently. I have more CNC background, and lots of electronics/software bg so I learn quickly but I've learned more in the last month on Marlin and 3D printer tuning than the last 5 years. I had some of these issues and I taped a part cooling fan to the front of the carriage. Like fully-enclosed for ABS, I've heard you dont need a part cooling fan but I disagree - I think we do especially for small parts with little infill and fast layers. I dont think we need much cooling, just a bit. I am just doing my first PLA print and omg can I ever see the difference in material. The PLA hardens like candy apple and seems almost brittle. ABS is always soft, almost molten, for much of the current layer. I have my second extruder operating with PLA and I've carefully tuned their heights and trammed with a feeler gauge yet still any little over extrusion and the other nozzle makes a *crackling* sound as it runs over it. ABS would still be soft. So far it is working though...first time I've had dual extrusion working since I got the machine. I love how Makerbot called it the "Experimental" printer, I thought the marketing label meant 'I can experiment' only we later found out they literally meant this dual extrusion printer was an experiment of theirs. I.e. "we didnt know for sure if it would work". (Apparently this was no joke.)|
Re: Reviving a Makerbot Replicator 2X August 25, 2020 06:28AM |
guru_florida
Just from the videos that is a fast print speed!Since you did the extrusion calibration, I can only surmise it might be just layers printing too fast. Maybe try a larger part? You seem to be more knowledgeable in printing than I am so take any my advice with a grain of salt. I've been doing 3D printing since ~2014 but not consistently. I have more CNC background, and lots of electronics/software bg so I learn quickly but I've learned more in the last month on Marlin and 3D printer tuning than the last 5 years. I had some of these issues and I taped a part cooling fan to the front of the carriage. Like fully-enclosed for ABS, I've heard you dont need a part cooling fan but I disagree - I think we do especially for small parts with little infill and fast layers. I dont think we need much cooling, just a bit. I am just doing my first PLA print and omg can I ever see the difference in material. The PLA hardens like candy apple and seems almost brittle. ABS is always soft, almost molten, for much of the current layer. I have my second extruder operating with PLA and I've carefully tuned their heights and trammed with a feeler gauge yet still any little over extrusion and the other nozzle makes a *crackling* sound as it runs over it. ABS would still be soft. So far it is working though...first time I've had dual extrusion working since I got the machine. I love how Makerbot called it the "Experimental" printer, I thought the marketing label meant 'I can experiment' only we later found out they literally meant this dual extrusion printer was an experiment of theirs. I.e. "we didnt know for sure if it would work". (Apparently this was no joke.)
Back to full enclosure. I think it is important, especially for ABS, but it means many other things have to be carefully tuned. I am having an issue where the enclosure temp get too high that the steppers cant cool enough, and the stepper heat eventually cause the filament to molten at the gear. I let the first few layers print then I raise the cover up 2 inches and open the door a crack for the rest...this is enough to keep the steppers <60degC. Not an issue with Bowdens. I've also seen where the enclosure is keeping the part from cooling down enough too though which is like what you are seeing. Possibly keep the door open a bit.
My PLA is printing with a new thin stepper and omg it is running so much cooler even though I am powering it at 700mA vs 500mA on the old one. I expected it to be hotter but would give me enough room to attach heatsinks and keep it cooler. Hoping these work good.
[www.amazon.com]
Colin
Re: Reviving a Makerbot Replicator 2X August 25, 2020 08:51PM |
Re: Reviving a Makerbot Replicator 2X August 26, 2020 09:32AM |
guru_florida
I didnt even realize in the youtube videos that there was no sock on your hotend! Yes, not having a sock was part of my issue a few months back. I didnt think it mattered *that* much but the hotend aluminum block was keeping the top of the part molten. I did a crappy job of wrapping mine in scraps of soft felt (whatever that stuff is called) and kapton and it looked like crap but definitely worked. lol. With the new hotends I have the full silicon sock which is awesome since no plastic sticks to them. The sheer amount of "process variables" that all need to be controlled is crazy in 3D printing. Also we need to control heat here, cool these over there, cool the part, but overall control ambient heat the interdependence are crazy. Thus my water-cooled experiment.
New mount looks great!
I got my dual extruders working good but I know the limitations of it....and I know long term I wont be happy lol. I am thinking of designing a dual printing head like this one and maybe a cross between a few other "dual head switching extruder" designs. I was thinking there must be a way to have the two extruders fixed together but slide one out of the way while the other slides in and sure enough lots of existing stuff out there. I'd also like it to share the same extruder motor to reduce weight so the switching of the head loosens tension on one filament while it engages the other. Long term project though, I'm good for now and except for a few tweaks I'm going to enjoy that I have a 3D printer again. I also have to get back on a humanoid robot project.
[www.youtube.com]
Re: Reviving a Makerbot Replicator 2X August 28, 2020 07:02AM |
Re: Reviving a Makerbot Replicator 2X September 05, 2020 03:24PM |
Ohmarinus
I think I've got it down almost completely now.
In contrary to what seems to be popular belief, on my machine I can print perfectly with a bed temperature of 80ºC and a hotend temperature of 235ºC. I read everywhere people suggest an even higher bed temperature when experiencing warping, but in my personal experience I experience no warping at all at 80ºC (first layer temp is 85ºC). Lowering the bed temp might be quite counter-intuitive to some people, but I realized that was the last thing to try that I could think of. Now the material solidifies enough to not warp, but it stays hot enough to still have good inter-layer adhesion. No issues with the part coming off the bed, I still have to use extreme force to get it off. I guess my blend of ABS juice is also exactly the right consistency. I see a lot of people smear on thick-ass layers of ABS juice, but you really only need a subtle film.
Also, I've added a fan duct that I printed with the Delta machine I've built as well. And am now in the process of vapor smoothing the part that I reprinted with the Replicator 2x which I now call Replicator 3x since it's been upgraded by me. This fan duct will also help with air flow being minimized over the part that's being printed as I did notice that even though my new X-carriage design works incredibly well **best I've ever designed so far**, there was still some turbulence being pulled under the carriage by the airflow that is sucked into the 40mm hotend cooling fan.
I used this design as I see it's the best one I could find with good flow characteristics. I don't understand why people use grate-type fan guards/ducts/inlets, they 'suck':
Some example images:
Re: Reviving a Makerbot Replicator 2X September 15, 2020 11:24PM |
Ours are both basically the same upgrade except for our extruder design...so you dont sue me I may have to use Replicator 3Z and Z is for Zombie.|
Re: Reviving a Makerbot Replicator 2X December 09, 2020 02:20AM |
Re: Reviving a Makerbot Replicator 2X January 13, 2021 02:42PM |
Ohmarinus
Okay, a small update on the machine, and a copy paste from the other topic in 'Printing issues':
Ohmarinus
I have changed a lot of settings and the machine is performing really well now. I've also designed myself a PWM breakout module to run an extra fan with PWM because I use one PWM controlled fan to cool the hotend (though I run it on 255 anyway but might lower it again to make it more quiet again) and then I use another fan to cool down the stepper drivers.
This is it:
Couldn't find how many PWM fans could be run on the SKR 1.4 natively, but I decided on creating a breakout board as an exercise anyway. It was a lot of fun.
Re: Reviving a Makerbot Replicator 2X January 13, 2021 02:43PM |
guru_florida
Hey Ohmarinus! How is the machine running now?
I am considering moving to single extruder and bowden-pusher instead of my extruder on the carriage. I just find dual extrusion such a pain to tune and 95% of the time I just want single head. Also, my glass plate cracked a bit (my own fault) and although it still works fine for now I am thinking PEI sheet is in order. What are you using for build plate?
