Printer pauses a lot June 17, 2011 02:27PM |
Re: Printer pauses a lot June 19, 2011 05:55PM |
Re: Printer pauses a lot June 19, 2011 06:33PM |
Re: Printer pauses a lot June 20, 2011 05:59PM |
Re: Printer pauses a lot June 20, 2011 07:32PM |
Re: Printer pauses a lot June 20, 2011 07:57PM |
Re: Printer pauses a lot June 20, 2011 10:20PM |
Re: Printer pauses a lot June 21, 2011 11:10AM |
Re: Printer pauses a lot June 23, 2011 10:34AM |
Re: Printer pauses a lot June 23, 2011 12:45PM |
Re: Printer pauses a lot June 23, 2011 03:35PM |
Re: Printer pauses a lot June 24, 2011 09:52AM |
Re: Printer pauses a lot June 24, 2011 09:54AM |
Re: Printer pauses a lot June 24, 2011 10:05AM |
I always run the extruder manually before a print, so that would seem to explain it.Quote
RepRap Wiki
Extruder running backwards at start of print
Technically this is not a problem with Skeinforge, but you can make a simple change in Skeinforge to work around it. The issue is caused by manual extrusion (through RepRapHost, RepSnapper) prior to a print changing the E value calculated by your firmware.
To fix, in your start.gcode file add the command 'G92 E0' which resets the E count to 0.
Re: Printer pauses a lot June 24, 2011 10:31AM |
Re: Printer pauses a lot June 24, 2011 11:27AM |
Re: Printer pauses a lot June 24, 2011 12:40PM |
Re: Printer pauses a lot June 24, 2011 04:17PM |
Re: Printer pauses a lot July 04, 2011 12:42PM |
Re: Printer pauses a lot August 18, 2011 04:29AM |
Re: Printer pauses a lot August 30, 2011 12:21AM |
Re: Printer pauses a lot November 12, 2011 04:15PM |
Re: Printer pauses a lot November 12, 2011 04:57PM |
Re: Printer pauses a lot November 13, 2011 09:30AM |
Exception in thread Thread-1: Traceback (most recent call last): File "/usr/lib/python2.6/threading.py", line 532, in __bootstrap_inner self.run() File "/usr/lib/python2.6/threading.py", line 484, in run self.__target(*self.__args, **self.__kwargs) File "/home/tim/Dropbox/aa_Prusa/kliment-Printrun-2a1ef25/printcore.py", line 79, in _listen line=self.printer.readline() File "/usr/lib/python2.6/dist-packages/serial/serialutil.py", line 60, in readline c = self.read(1) File "/usr/lib/python2.6/dist-packages/serial/serialposix.py", line 320, in read buf = os.read(self.fd, size-len(read)) OSError: [Errno 11] Resource temporarily unavailable
Re: Printer pauses a lot November 23, 2011 08:21PM |
Re: Printer pauses a lot November 23, 2011 11:56PM |
Re: Printer pauses a lot November 24, 2011 08:14AM |
Re: Printer pauses a lot November 25, 2011 07:03AM |
