Anet A8 Marlin 2.0 Firmware Cura Slicer OctoPrint Stops are not working
Posted by NaderHamzei
July 22, 2020 05:31PM
I updated my ANET A8 to the optiloader with an Arduino Uno and uploaded the Marlin build with Visual Code.
The only issue I am is my X Y & Z Stops are not working properly. I am using OctoPrint and with the Terminal Viewer I can see that the Stops are properly triggered when I manually press one stop and issue a 'M119' command. It states trigger and the open ones are marked open. But the printer steppers aren't stopping when it triggers the stop.
Inside the Configuration.h file I found the following:
// Enable pullup for all endstops to prevent a floating state
#define ENDSTOPPULLUPS
// Enable pulldown for all endstops to prevent a floating state
//#define ENDSTOPPULLDOWNS
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup).
#define X_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // Set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING false // Set to true to invert the logic of the endstop.
#define Z_MIN_PROBE_ENDSTOP_INVERTING true // Set to true to invert the logic of the probe.
Should I comment out '#define ENDSTOPPULLUPS' and uncomment '#define ENDSTOPPULLDOWNS'?
What should the proper MIN & MAX boolean be for the endstops?
Any other ideas what it could be? Thanks in Advance!
Re: Anet A8 Marlin 2.0 Firmware Cura Slicer OctoPrint Stops are not working
July 22, 2020 10:57PM
Use the example config files from [github.com]
July 25, 2020 04:30PM
ok, I tried those and have a build error. I am using Marlin 2.0.5.3 March 30, 2020. could this be a mismatch
below is the build results. And below that is an error in _Statusscreen.h that is new
BUILD RESULTS:
Compiling .pio\build\sanguino1284p\src\src\module\endstops.cpp.o
Compiling .pio\build\sanguino1284p\src\src\module\motion.cpp.o
Compiling .pio\build\sanguino1284p\src\src\module\planner.cpp.o
Compiling .pio\build\sanguino1284p\src\src\module\planner_bezier.cpp.o
Compiling .pio\build\sanguino1284p\src\src\module\printcounter.cpp.o
Marlin\src\module\motion.cpp:77:71: error: 'X_HOME_BUMP_MM' was not declared in this scope
#define XYZ_CONSTS(T, NAME, OPT) const PROGMEM XYZval NAME##_P = { X_##OPT, Y_##OPT, Z_##OPT }
Marlin\src\module\motion.cpp:83:1: note: in expansion of macro 'XYZ_CONSTS'
XYZ_CONSTS(float, home_bump_mm, HOME_BUMP_MM);
Marlin\src\module\motion.cpp:77:80: error: 'Y_HOME_BUMP_MM' was not declared in this scope
Marlin\src\module\motion.cpp:77:89: error: 'Z_HOME_BUMP_MM' was not declared in this scope
*** [.pio\build\sanguino1284p\src\src\module\motion.cpp.o] Error 1
=================================================================== [FAILED] Took 111.28 seconds ===================================================================
Environment Status Duration
mega2560 IGNORED
mega1280 IGNORED
rambo IGNORED
FYSETC_F6_13 IGNORED
FYSETC_F6_14 IGNORED
sanguino644p IGNORED
sanguino1284p FAILED 00:01:51.275
melzi IGNORED
melzi_optiboot IGNORED
at90usb1286_cdc IGNORED
at90usb1286_dfu IGNORED
DUE IGNORED
DUE_USB IGNORED
DUE_debug IGNORED
LPC1768 IGNORED
LPC1769 IGNORED
STM32F103RC IGNORED
STM32F103RC_fysetc IGNORED
STM32F103RC_btt IGNORED
STM32F103RC_btt_USB IGNORED
STM32F103RC_btt_512K IGNORED
STM32F103RC_btt_512K_USB IGNORED
STM32F103RE IGNORED
STM32F103RE_btt IGNORED
STM32F103RE_btt_USB IGNORED
STM32F4 IGNORED
STM32F7 IGNORED
ARMED IGNORED
STM32F103VE_GTM32 IGNORED
STM32F103VE_longer IGNORED
mks_robin_mini IGNORED
mks_robin_nano IGNORED
mks_robin IGNORED
mks_robin_pro IGNORED
mks_robin_lite IGNORED
mks_robin_lite3 IGNORED
jgaurora_a5s_a1 IGNORED
STM32F103CB_malyan IGNORED
chitu_f103 IGNORED
STM32F401VE_STEVAL IGNORED
FLYF407ZG IGNORED
FYSETC_S6 IGNORED
STM32F407VE_black IGNORED
BIGTREE_SKR_PRO IGNORED
BIGTREE_GTR_V1_0 IGNORED
BIGTREE_BTT002 IGNORED
teensy31 IGNORED
teensy35 IGNORED
esp32 IGNORED
linux_native IGNORED
SAMD51_grandcentral_m4 IGNORED
rumba32_f446ve IGNORED
rumba32_mks IGNORED
include_tree IGNORED
=============================================================== 1 failed, 0 succeeded in 00:01:51.275 ===============================================================
Line 42 _Statusscreen.h expected a ';'[42,49]
const unsigned char status_logo_bmp[] PROGMEM = {
B01110000,B00000000,B00001000,B00000011,B10001110,
B10001000,B00000000,B00001000,B00000100,B01010001,
B10001010,B11000111,B00111110,B00000100,B01010001,
B11111011,B00101000,B10001000,B00000111,B11001110,
B10001010,B00101111,B00001000,B00000100,B01010001,
B10001010,B00101000,B00001000,B00000100,B01010001,
B10001010,B00100111,B00000110,B00000100,B01001110
suggestions?
July 26, 2020 12:03AM
your using an older marlin, that is the latest config files.
use config files that match your version from [github.com]
