Overtemperature warning problem
July 24, 2020 06:39PM
I'm trying to set up Marlin 2.0.x on an MKS Gen L V2.0 and I can't figure out why the printer keeps sending overtemperature warnings to pronterface.
Here are my errors:
Testing X connection... OK
Testing Y connection... Error: All HIGH
Testing Z connection... Error: All LOW
Testing E connection... OK
00:00: Y driver overtemperature warning! (800mA)
is there something I'm doing wrong?
Re: Overtemperature warning problem
July 25, 2020 02:19AM
Error: All HIGH will cause all sort of issues...
Check your jumpers and try swapping driver around, if fault moves the driver might be faulty
July 29, 2020 01:39PM
I swapped Y and Z and got
Testing X connection... Error: All HIGH
Testing Y connection... Error: All LOW
Testing Z connection... OK
then I swapped (I think) E and Y and got
Testing Z connection... Error: All HIGH
also, what does ALL HIGH mean?
July 29, 2020 01:51PM
All high means that the controller asked the stepper driver for information and all it got back was lots of 1's, all high.
It doesn't tell you anything about why...
July 29, 2020 02:26PM
I figured out that I might have faulty drivers, I've been moving them and I always have an OK, an ALL LOW, and two ALL HIGH errors. I just sorted them by connection problem
Testing E connection... Error: All HIGH
00:00: Z driver overtemperature warning! (800mA)
00:00: E driver overtemperature warning! (800mA)
July 30, 2020 02:27AM
What drivers do you use, from what brand? Did you hook up the cables when testing them? Did you unplug cables while the power was on? How are they connected?
I've never seen so many drivers giving off an error. I can imagine maybe one not working correctly but if two or three are wonky there's usually something else going on.
http://www.marinusdebeer.nl/
