DIY high temp printer build August 29, 2020 06:46AM |
Re: DIY high temp printer build August 29, 2020 08:06AM |
Re: DIY high temp printer build August 29, 2020 11:08AM |
Re: DIY high temp printer build September 11, 2020 01:40PM |
Re: DIY high temp printer build September 11, 2020 01:46PM |
Re: DIY high temp printer build September 11, 2020 02:47PM |
Admin Registered: 11 years ago Posts: 3,096 |
Rik Snelder
The top side is made op polycarbobonate, but the motion system will be covered up by the bellows so you won't be able to see from above anyways...
However, there is a polycarbonate window in the front door, so you can see the print
Also I might add a camera to the inside later
