MKS Gen L both temps at ~100deg when cold
Posted by flobo79
September 13, 2020 05:45AM
Hey team, out of the blue my MKS Gen L based printer shows a temp of about 100 deg (HE: 98, Bed: 96). They both started doing it on the same day. So my question is how likely is to that both termistors blow up at the same time? And how would you start debugging that issue?
Thanks for help!
VDX
Re: MKS Gen L both temps at ~100deg when cold
September 13, 2020 06:37AM
... if not the thermistors, then eventually the measuring system -- REF voltage OK? ... input pins OK?
Viktor
September 13, 2020 07:05AM
Is symptomatic to ADC port being damaged.
