Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 15, 2020 01:08AM |
Re: Help Needed - Custom Built 3d Printer ![]() September 15, 2020 02:49AM |
Admin Registered: 8 years ago Posts: 3,093 |
Re: Help Needed - Custom Built 3d Printer ![]() September 15, 2020 10:01AM |
Re: Help Needed - Custom Built 3d Printer ![]() September 15, 2020 10:11AM |
Re: Help Needed - Custom Built 3d Printer ![]() September 15, 2020 12:05PM |
Re: Help Needed - Custom Built 3d Printer ![]() September 15, 2020 11:28PM |
Re: Help Needed - Custom Built 3d Printer ![]() September 15, 2020 11:41PM |
You beauty!! You are spot on. I did your test and it’s exactly 8mm is the length travelled.. I have changed the settings in Marlin.Quote
Roberts_Clif
Looking at your attached photo I see your lead screws and you should change the configurations 80, 80, 1600, 94.54.
The 1600 was meant for a T8x2 not your T8x8 lead screw.
If you place a mark on the lead screw while the nozzle is on the bed. Then turn the lead screw 360 degrees (one full revolution)
You will see the the nozzle moves 8mm up the 1600 was designed for a lead screw that only moves 2mm up.
Your settings should start here 80, 80, 400, 94.54 or 80, 80, 398, 94.54 in some cases this 2mm makes a the model closer to the correct size.
This is only a suggestion as viewed from a photo.
Re: Help Needed - Custom Built 3d Printer ![]() September 15, 2020 11:47PM |
Ohmarinus
Not bad for a first try!
First of all, what filament are you using? PLA? ABS? PETG?
If it's PLA, you need a hotend that has PTFE tube in the throat or else the filament can get stuck if the surface isn't perfectly smooth inside of the hotends throat/transition zone. Also, if it's PLA, you need a part cooling fan. But the print seems to fail because the filament gets stuck as I can see the further up the print gets, the less is extruded.
Does the extruder maybe skip steps, or can it be that the gear is grinding on the filament?
Second, the cantilever on the Z-axis where the nuts are seated in looks like it could give issues with flexing, Z-height is very important. The flex might cause variances in Z-height and might add layer-artifacts.
Above all, I think it's a nice first try, the machine already looks like a good first try and once you get it to print, you can design and print better X-ends that hold the Z-nut.
Re: Help Needed - Custom Built 3d Printer ![]() September 16, 2020 01:41AM |
Re: Help Needed - Custom Built 3d Printer ![]() September 16, 2020 05:22AM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 16, 2020 07:55AM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 16, 2020 09:15AM |
Roberts_Clif
When you have a problem remember we are he to help, but not just for when you are in need of help.
Come back, read the posts see if your experiences can help others.
I would assume that after building a complete 3D Printer from scratch you have a lot experiences to give and to help others.
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 16, 2020 09:37AM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 16, 2020 09:39AM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 16, 2020 11:10PM |
Roberts_Clif
Looking at your CaliCat I see the edges are still a little ruff could you post your Mattercontrol slicer settings as I see no Mattercontrol thread continue here.
BalajiS
[attachment 116734 CaliCat.jpg]
It appears that the bed is a little high on the leveling springs this could cause some or all of the lines on your CaliCat, though some could be corrected by Mattercontrol settings.
[attachment 116737 Springs.jpg]
Re: Help Needed - Custom Built 3d Printer ![]() September 17, 2020 08:28AM |
Dust
Y stepper driver could be getting to hot, if so they shut down to cool off then continue.
BalajiS
Whats still skewed.
1. Looks like i have a series layer shift (right from the second Layer itself)
2. I hear a horrible motor sound. Not sure if there is something wrong with motor or some voltage change needs to happen.. it see its getting hot sometimes. i meassured the voltage and ist 0.5 to .60 on all stepper
Observations:
1. After slicing it in Mattercontrol. I see the Y Axis during completion of the first Layer moves diagonally to the start point. The movement is very slow or slightly jitters (attached the video). This happens for on the end of 2nd Layer also so its obvious shift after every layer. But other Y axis movement is fine. Something is not correct really. This did happened before also and the printer halted saying hardware error!!
What i checked after the observation?
1. I removed the Y axis motor wires, checked if the Y axis moves freely, fine tuned the eccentric nut also (but thats the max i can loose the eccentric nut). The belts looks fine, Y axis moves freely than X axis actually
Stock | Red | Blu X-Axis - 0.8 .695 .395 Y-Axis - 0.8 .695 .395 Z-Axis - 1.0 1.639 .710 --- one Pair Parallel Nema 17 Bipolar 1.5A 36.6oz E0-E1 - 0.8 .695 .395
Re: Help Needed - Custom Built 3d Printer ![]() September 17, 2020 10:23PM |
BalajiS
1. Still Y Axis after few hours moves/Jitters slowly in diagonal...
Re: Help Needed - Custom Built 3d Printer ![]() September 18, 2020 12:17AM |
Roberts_Clif
I have a Hictop 3DP11/12 and using Nema 17 Bipolar 1.5A 57oz.in or compatible stepper motors, I have set my Steppers according the the chart below.
Note:: Stock was running the steppers too hot, Red is a 24V and Blu is 12V 3D Printers
Re: Help Needed - Custom Built 3d Printer ![]() September 18, 2020 12:18AM |
frankvdh
BalajiS
When things go wrong after a period of time, usually the problem is heating or cooling. If your Y axis motor or (more likely) stepper driver is overheating, it will skip steps and make the horrible graunching noise you describe, and of course the carriage won't move in that axis, or only move in one direction. Try heatsinks and a fan blowing on your stepper drivers. Or you could slow the print down, or pause it every few minutes, so that natural cooling can keep it cool. I think that if you have too much current going to your stepper, it causes overheating and the same thing happens. And if your stepper current is too low, it doesn't cause overheating, but it also causes steps to be skipped.
But do also check that there's no extra friction in the Y axis at that point in the movement. And that your wires and filament feed to the carriage are long enough and not catching on anything. Probably best would be to move the carriage to that position manually and try moving it around a bit.
Re: Help Needed - Custom Built 3d Printer ![]() September 18, 2020 08:07AM |
Roberts_Clif
Note:: Stock was running the steppers too hot, Red is a 12V and Blu is 24V 3D Printers
Re: Help Needed - Custom Built 3d Printer ![]() September 18, 2020 11:25PM |
Roberts_Clif
Sorry my 3D Printer Power Supplies voltages are backwards.
Roberts_Clif
Posting My 3D Printer Cura Settings
[attachment 116773 Cura3.6.0.zip]
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 19, 2020 03:51AM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 19, 2020 07:17AM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 21, 2020 08:49AM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 21, 2020 01:00PM |
adjective: insinuating hinting at something bad in an indirect and unpleasant way.
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 21, 2020 01:37PM |
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 21, 2020 07:04PM |
Roberts_Clif
@MKSA
Is there a reason why you are Insinuating most posts you respond too.
This is suppose to be RepRap 3D Printer forum, which gathers information from users worldwide that has the most informative posts.
Most users of RepRap forum have RepRap components attached to their 3D Printers of which is inquires to troubleshooting assistance.
Insinuating 3D Printer DIY builds and that they should immediately purchased a Kit is not helpful to them or to RepRap Forum.
Who knows one of his designs could very well be RepRap newest hottest sales items on the market over the next few years.
Diagnosing problems and passing information on to those reading the posts is what RepRap 3D Printer Forum was created.
@BalajiS
It was my moment of dyslexia the supply voltages from one 3D Printer to the Other were reversed.
I knew better just got by me during that post..
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 21, 2020 07:41PM |
dlc60
MKSA sometimes has good points, he isn't always up on the wrong side of the bed. He sometimes posts good links to the experts.
Fortunately, the experts on the lists have nearly endless patience with those of us who are re-discovering what others have often already perfected over time.
Occasionally, someone comes up with something truly new and innovating - That is always worth waiting for.
It is said that science doesn't progress until the old guard dies off. Many of the "old guard" here are still interested in the ideas from the newcomers who don't know what isn't possible yet.
DLC
Re: Help Needed - Custom Built 3d Printer - Finally Printing ![]() September 22, 2020 07:51AM |
