Heatsink pastes for hotends September 17, 2020 11:21AM |
Re: Heatsink pastes for hotends September 17, 2020 12:37PM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Heatsink pastes for hotends September 17, 2020 01:16PM |
Re: Heatsink pastes for hotends September 17, 2020 01:46PM |
leadinglights
The hotend is my own design but uses a vitreous enamel wirewound resistor instead of a heater cartridge. The reason for this is that I was an early adopter of heater cartridges but they let me down badly - I have never had a WW resistor fail.
Part of the problem here is that this design uses a very small resistor which is over-run to the wazoo and beyond: The element wire temperature gets to 420°C with the block at 280°C. Although I ran resistors in dummy heater blocks at 280°C for over 1000 hours without failure to test them, the design of the resistors I use has been changed so that the outside diameter is nearly 0.4mm less than the ones I tested.
[attachment 116760 DSCF0395B.jpg]
Combine the tiny resistor, the looser fit, and the lack of my miracle grease and I think you can guess why I am worried.
Mike
I'll see if I can dig them up.|
Re: Heatsink pastes for hotends September 17, 2020 02:25PM |
Re: Heatsink pastes for hotends September 17, 2020 05:02PM |
leadinglights
I have found 3 of the original 5 dummy hotend blocks that I used some years ago to do the failure test. I think I will try a repeat of the earlier test with different compounds - with and without copper shims to fill the gap. Machining new blocks to fit the resistors would be a pain - and wouldn't guarantee that the next batch would have the same diameter.
Mike
Re: Heatsink pastes for hotends September 17, 2020 08:55PM |
Re: Heatsink pastes for hotends September 18, 2020 04:59AM |
the_digital_dentist
.................. Is your extruder having some sort of problem?
Re: Heatsink pastes for hotends December 10, 2020 11:56AM |
Re: Heatsink pastes for hotends December 10, 2020 04:08PM |
Re: Heatsink pastes for hotends December 11, 2020 05:42AM |
the_digital_dentist
................................................................................. Why mess around with resistors that are not designed for the purpose?
Re: Heatsink pastes for hotends December 11, 2020 09:50AM |
Re: Heatsink pastes for hotends December 11, 2020 10:58AM |
Re: Heatsink pastes for hotends December 13, 2020 08:28AM |
Re: Heatsink pastes for hotends December 13, 2020 09:53AM |
Re: Heatsink pastes for hotends December 13, 2020 10:01AM |
leadinglights
While I am not unconcerned about the possibility of failure, this is only because of the very small size of the resistors I am using, not because there is any problem with the materials or the construction of wirewound resistors which render them unsuitable for this purpose. I would also not expect a 3D printer manufacturer to use them, but this is because variables that do not affect their design intent of providing electrical resistance but would be less good in a heater. These differences, such as local enamel thickness changes, can be avoided by hand selection.
Re: Heatsink pastes for hotends December 13, 2020 10:31AM |
the_digital_dentist
...................................... Do you think a 3W resistor uses the same diameter nichrome wire that a 30W resistor (or a 30W heater cartridge) uses?............................................
Re: Heatsink pastes for hotends December 13, 2020 10:49AM |
Re: Heatsink pastes for hotends December 13, 2020 12:05PM |
Re: Heatsink pastes for hotends December 14, 2020 09:30AM |
Re: Heatsink pastes for hotends December 14, 2020 10:10AM |
Re: Heatsink pastes for hotends December 14, 2020 11:01AM |
Re: Heatsink pastes for hotends December 23, 2020 04:22AM |
Re: Heatsink pastes for hotends December 23, 2020 05:58AM |
Re: Heatsink pastes for hotends December 23, 2020 10:54AM |
Re: Heatsink pastes for hotends December 23, 2020 02:01PM |
Re: Heatsink pastes for hotends February 21, 2021 07:12AM |
Re: Heatsink pastes for hotends February 24, 2021 11:35AM |
Re: Heatsink pastes for hotends February 24, 2021 04:41PM |
Re: Heatsink pastes for hotends February 25, 2021 09:07AM |
