Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB October 31, 2020 10:48PM |
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 02, 2020 12:51AM |
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 02, 2020 11:15PM |
MKSA
- A steel acorn nut against a plastic surface is not a very good choice for such mount.
- Looking at the bed, part 22 roll mount made out of plastic, the way it is attached to the glass/heater,composite plate can you explain how it is a "kinematic mount" ?
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 02, 2020 11:57PM |
doublec4
MKSA
I printed those black mounting pieces from nylon carbon fiber. There *should be* no relative movement between the cap nut and the plastic parts... so far I haven't seen any wear on the plastic component.
Hopefully it is not false advertising, but I designed the 3 mounting points based on the kinematic mounting principles (of how I understand them at least):
[wp.optics.arizona.edu]
One of the screws (back left, part 22) is the reference adjustment (cone shape receptacle on the round cap nut), the second screw (back right, part 22) is the pitch adjustment (slotted cone shape receptacle on the round cap nut), the third screw (foremost, part 10) is the roll adjustment (flat plane on the round cap nut). For some reason on the BOM, the part number and description of those two parts is sort of at odds with one another. Not sure how they got reversed.
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 03, 2020 06:18AM |
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 05, 2020 07:50PM |
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 05, 2020 09:49PM |
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 05, 2020 10:03PM |
Re: Revived a Dremel 3D20... Duet 2 Wifi, PanelDue, kinematic bed, hot swap PCB November 06, 2020 04:57AM |
MKSA
leadinglights
As far as I can see, your kinematic mount should work satisfactorily although you may find unwanted behavior with heating or cooling of the build stage....
Mike
No, it doesn't.
MKSA
I saw that too plus other issues.
Anyway.
