Heated Chamber Advice November 06, 2020 06:31PM |
Re: Heated Chamber Advice November 07, 2020 05:07AM |
Re: Heated Chamber Advice November 07, 2020 11:33AM |
Re: Heated Chamber Advice November 19, 2020 02:04PM |
Re: Heated Chamber Advice November 20, 2020 06:49AM |
boggen79
automotive -> radiator hose, coolant hose.
tractors small and large -> radiator hose, coolant hose, hydraulic hose,
lawn mowers, small engines (2 cycle, 4 cycle engines such as chain saws and weed eaters / trimmers) = shops should have high end temperature hose.
make sure you read up on "min bend radius" for hose.
google "min bend radius hose" i want to say it is 3 or 5 times outside diameter of hose. example 1" outside diameter hose, can bend 3 to 5" in diameter, past that and hose will most likely kink or will form a kink. do not trust my numbers and google it to check.
