From the discord, where they also posted
you need to identify your controller
your github called MKS_GEN_L motherboard is set to BOARD_RAMPS_14_EFB not BOARD_MKS_GEN_L and the github you said moved a little is set to MKS_GEN_L_V2
so which do you actually have?
the reddit post say "Ender 3 with a MKS GEN L V2"
so you should have #define MOTHERBOARD BOARD_MKS_GEN_L_V2
in fact provided configuration in [
github.com] is stock, not customized at all!
start with the config for an ender 3 with orrginal controller
and update motherboad to BOARD_MKS_GEN_L_V2
and go from there.
github.com]
also make sure you disable CR10_STOCKDISPLAY and enable REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER so your dispaly works.
Edited 1 time(s). Last edit at 11/09/2020 07:37AM by Dust.
