Wisamic Heater RRF config settings
Posted by WilberMaker
May 24, 2021 09:21AM
Not sure where to put this. I am using a Wisamic silicone 120v heater for the first time. Trying to set up RRF on a Duet. The description call out the Thermistor is 100K "3950". How do I translate this over to the configuration settings? I'm looking for the "PWM Limit", "R25", "B", and "C" settings?
Thanks for any help
Re: Wisamic Heater RRF config settings
May 25, 2021 02:13AM
I presume that is a bed heater, in which case you will have enough accuracy without the C term. Use T100000 B3950 C0.
May 25, 2021 01:08PM
Yes its a bed heater. Thank you for the info
