Which glass for heated bed September 06, 2021 05:13AM |
Re: Which glass for heated bed September 06, 2021 11:35AM |
Re: Which glass for heated bed September 06, 2021 12:16PM |
Re: Which glass for heated bed September 06, 2021 08:29PM |
MStarha
I am building my CoreXY 3D printer with 350x350 mm heated bed at about 4mm thickness. I just found out that borosillicate glass is unavailable at the local glazier. He offered tempered or ceramic glass instead. Which one should I go for? I read that both are a more expensive option to borosilicate glass, but I worry about the temperature stability, warping of the glass (in case of the tempered one) and parts (not) sticking to it. Any experience is appreciated.
PS. The ceramic glass at this size would cost me about 45 USD. The glazier did not tell me the prize of the tempered option, but I reckon it will be around 30 USD, which is much more acceptable if it does the same job.
Re: Which glass for heated bed September 07, 2021 02:48AM |
MStarha
I am using 300x300 mm Keenovo silicone heater on 5 mm thick 350x350mm cast aluminium plate. And I intend to print PETG and ABS mostly, that means up to 100-120 degrees on the heated bed. That might cause some stress in the glass. Will the ordinary float glass survive? Any thoughts on that?
Re: Which glass for heated bed September 07, 2021 02:56AM |
Re: Which glass for heated bed September 07, 2021 09:04AM |
dc42
MStarha
Float glass will be fine in that setup, certainly with PETG. I mostly print PETG, but I have printed ABS a few times with the bed at 100 to 120C. The only times I have damaged a bed is when the print has stuck to it so well that it took a few shards of glass with it when it came off.
It's handy to have several beds so that when a print finishes, you can remove the bed+print and start another print on a new bed, instead of having to wait for the print to cool down enough for you to remove it.
Re: Which glass for heated bed September 07, 2021 09:46AM |
Re: Which glass for heated bed September 12, 2021 02:27AM |
