bed leveling with CNC-methods
January 13, 2022 05:45PM
I've recently used the same method as CNC hobbyists use to zero out their work-piece (see picture below), by using my printers nozzle as a probe that lights up an LED as soon as it touches a PCB.
That worked extremely well, however I am puzzled as to how it ended up working - by sheer logic I would need to subtract the Z-height at which I was calibrating, which in my case was at Z1.2, so I assumed I would have to G206 a Z1.2 in marlin to correct for that..
However that ended up being way too close to the bed (even though my printer has a Z0.30 start g-code) - what ended up working was Z0.15, which is half of the Z0.30 set by my printer.
I'm close to believing it was marlin always z-stop'ing that dictated this, but why wouldn't it be then 1.2 off the bed still?
Does anyone have a clue / theory how that ended up working?
Thanks so much for any ideas!
Re: bed leveling with CNC-methods
January 14, 2022 05:43PM
how many points on the bed did you measure?
January 14, 2022 07:54PM
MechaBits
four total (each corner) - I ignored the middle as it's the result of them and I can't affect it directly, only with e.g. mesh-leveling.
Edited 1 time(s). Last edit at 01/14/2022 07:54PM by pickedtransmitted.
January 24, 2022 07:10AM
are you using 3 or 4 screws, either way 1.5 is about half your extrusion diam with a little squish, but the good thing is when its working you can forget about it & worry about something else, I start leveling my printer touching the bed, some z offset seems to raise things a little, but sometimes can be too close or too far, but either way I think it remembers where it was on its last jog
