Follow Up to "Vent Your Printer. Do it Now"
Posted by rq3
rq3
January 23, 2022 08:55PM
I trust this will not devolve into a political diatribe regarding vaccination, as did my previous post on this topic. Kudos to the forum moderators for their diplomatic handling.
However, I think a follow up is in order.
Last year I developed a severe allergic reaction to 3D printing of PLA. It was eventually treated with a phenomenally expensive gene suppressing ointment, recently approved by the FDA here in the US.
The dermatologist eventually surmised that the allergy MAY have been triggered due to various vaccinations, OR it may have just been a multi-year exposure to a constant irritant (FDM printing).
He did agree that the allergen was PLA, although a standard 3 day "patch test" indicated that my only allergy was to...gold.
In any case, I am about 98% recovered, and have added a HEPA filter and activated charcoal post scrubber to my printer, which allows me to carefully continue using this fascinating technology.
I do not wish anyone to go through what I experienced over the past 10 months, and strongly recommend that all 3D printers, of any type, be well vented so as to reduce or eliminate exposure to their by-products, whether resin or filament. I'm sure that the vast majority of users will never see a reaction like mine, but an ounce of prevention is worth a pound of cure.
Just my $0.02 worth.
Re: Follow Up to "Vent Your Printer. Do it Now"
January 23, 2022 10:07PM
Glad to hear you're doing better. Maybe you should not print PLA any more.
I get prescription meds through Canada Pharmacy. The stuff I use ships to me from New Zealand and costs 1/15th what it would at a US pharmacy. Look them up.
VDX
January 24, 2022 01:58AM
... the biggest problems with filaments are the additives -- dyes, melting and mechanical optimizers and others, mostly not documented for different reasons eye rolling smiley
Viktor
January 27, 2022 11:53AM
Quite glad to hear that you're doing better and thank you very much for the cautionary tale and sharing your experience!
rq3
January 27, 2022 04:39PM
obelisk79
Thank you, Sir! Doing the first print in quite some time, with the VDE extruder (see the tech section). The HEPA and charcoal filters seems to be keeping any reaction in check.
March 06, 2022 02:40PM
A couple of years ago I was worried about the health issues with 3D printing and contacted various filament suppliers about the issue as well as Professor Brent Stephens (https://onlinelibrary.wiley.com/doi/full/10.1111/jiec.12578).
I also invested in a tvoc/fine dust measuring device and designed several filter contraptions.
From what I observed the glue/liquids I used for bed adhesion (dimafix in my case) seem to be as bad or worse as the 3D printing itself, 95% of what I print is ABS, the other 5% igus/nylon/ppa etc.
Some filament suppliers also used advanced filtration systems for in house testing.
I ended up putting the 3D printer outside (my daughter was just a baby at that time), which solves all these issues with more certainty than any filter.
It was outside for 3 years and this has worked well when it wasn't freezing, it was inside a shelter (don't know the correct name for it) so was protected from the rain but not from the cold/moisture.
My printer uses igus bearings on igus sliders so rust isn't an issue, now it's inside because of some upgrades but I'll put it outside again when I'm finnished with those.
Bram
