#define X_PROBE_OFFSET_FROM_EXTRUDER 0 // X offset: -left +right [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 0 // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER 0 // Z offset: -below +above [the nozzle]
this say the nozzle and the probe are at the same location this is not accurate
If you using the same system as the video the probe is behind the hotend so you a minimum need to adjust Y to positive value
Z should probably be a -ve value as the probe point is lower the than hotend ttip
