I'm having trouble getting Marlin 2.0.9.3 work on Sanguinololu 1.3a control board
The faults include locked up stepper motors no temperature Output End stops not acknowledging And a lot of things are not working the .
The only thing that does seem to work OK is the out of filament sensor
After looking at verbose mode on my arduino ide I get these messages also uploading the firmware via a arduino as ISP
Sanguinololu control board 1.3a Microcontroller atmel 1284p pu
J tag disabled for end stop To work
Marlin 1.1.9.1 work perfectly
below error / config/config adv / pins
error log
/home/user/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /home/user/arduino-1.8.19/hardware -hardware /home/user/.arduino15/packages -tools /home/user/arduino-1.8.19/tools-builder -tools /home/user/arduino-1.8.19/hardware/tools/avr -tools /home/user/.arduino15/packages -built-in-libraries /home/user/arduino-1.8.19/libraries -libraries /home/user/Arduino/libraries -fqbn=Sanguino:avr:sanguino:cpu=atmega1284p -vid-pid=2341_0001 -ide-version=10819 -build-path /tmp/arduino_build_713268 -warnings=none -build-cache /tmp/arduino_cache_783826 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/user/Desktop/3dprinter/firmware/Marlin-2.0.x/Marlin/Marlin.ino
/home/user/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /home/user/arduino-1.8.19/hardware -hardware /home/user/.arduino15/packages -tools /home/user/arduino-1.8.19/tools-builder -tools /home/user/arduino-1.8.19/hardware/tools/avr -tools /home/user/.arduino15/packages -built-in-libraries /home/user/arduino-1.8.19/libraries -libraries /home/user/Arduino/libraries -fqbn=Sanguino:avr:sanguino:cpu=atmega1284p -vid-pid=2341_0001 -ide-version=10819 -build-path /tmp/arduino_build_713268 -warnings=none -build-cache /tmp/arduino_cache_783826 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.arduinoOTA.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=/home/user/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -verbose /home/user/Desktop/3dprinter/firmware/Marlin-2.0.x/Marlin/Marlin.ino
Using board 'sanguino' from platform in folder: /home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3
Using core 'arduino' from platform in folder: /home/user/.arduino15/packages/arduino/hardware/avr/1.8.5
Detecting libraries used...
/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR -I/home/user/.arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3/variants/sanguino /tmp/arduino_build_713268/sketch/Marlin.ino.cpp -o /dev/null
/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR -I/home/user/.arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3/variants/sanguino /tmp/arduino_build_713268/sketch/src/MarlinCore.cpp -o /dev/null
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/MarlinCore.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/core/utility.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/feature/pause.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/feature/runout.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/calibrate/G28.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/config/M301.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/config/M302.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/control/M80_M81.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/eeprom/M500-M504.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/feature/pause/M600.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/feature/runout/M412.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/host/M115.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/motion/G2_G3.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/queue.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M104_M109.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M105.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M106_M107.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M140_M190.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M155.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/gcode/temp/M303.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/endstops.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/motion.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/planner.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/settings.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/temperature.cpp
Error while detecting libraries included by /tmp/arduino_build_713268/sketch/src/module/tool_change.cpp
Generating function prototypes...
/home/user/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega1284p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_SANGUINO -DARDUINO_ARCH_AVR -I/home/user/.arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino -I/home/user/.arduino15/packages/Sanguino/hardware/avr/1.0.3/variants/sanguino /tmp/arduino_build_713268/sketch/Marlin.ino.cpp -o /tmp/arduino_build_713268/preproc/ctags_target_for_gcc_minus_e.cpp
/home/user/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_713268/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
Compiling libraries...
Compiling core...
Archiving built core (caching) in: /tmp/arduino_cache_783826/core/core_Sanguino_avr_sanguino_cpu_atmega1284p_69e06db4cea1daafc0a763812e40c218.a
Linking everything together...
Sketch uses 63574 bytes (48%) of program storage space. Maximum is 130048 bytes.
Global variables use 2636 bytes (16%) of dynamic memory, leaving 13748 bytes for local variables. Maximum is 16384 bytes.
/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega1284p -cstk500v1 -P/dev/ttyACM0 -b19200 -Uflash:w:/tmp/arduino_build_713268/Marlin.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2000-2005 Brian Dean, [
www.bdmicro.com]
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/user/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/home/user/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega1284P
Chip Erase delay : 55000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 128 0 no 4096 8 0 9000 9000 0xff 0xff
flash 65 10 256 0 yes 131072 256 512 4500 4500 0xff 0xff
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e9705 (probably m1284p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/tmp/arduino_build_713268/Marlin.ino.hex"
avrdude: writing flash (63574 bytes):
Writing | ################################################## | 100% 60.17s
avrdude: 63574 bytes of flash written
avrdude: verifying flash memory against /tmp/arduino_build_713268/Marlin.ino.hex:
avrdude: load data flash data from input file /tmp/arduino_build_713268/Marlin.ino.hex:
avrdude: input file /tmp/arduino_build_713268/Marlin.ino.hex contains 63574 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 35.70s
avrdude: verifying ...
avrdude: 63574 bytes of flash verified
avrdude done. Thank you.
hello
