Replcace Rotary Encoder
Posted by Das Sams
August 08, 2022 01:51PM
Hey guys!
I just got a secondhand Beast V2 from cultivate3D, which is equipped with a RepRap Full Graphic Smart Controller for controls. Unfortunately, during transport, the rotary encoder was pysically damaged and does not work anymore. Is there a suitable replacement part that I can solder in or anything else besides swapping the entire LCD board?
Thanks for any advice
Re: Replcace Rotary Encoder
August 08, 2022 08:59PM
The encoder with switch is a standard component on a RepRap Full Graphic Smart Controller
There are different height and types of shafts... It depend what knob they used on it.
one seller I use is [www.aliexpress.com]
Edited 1 time(s). Last edit at 08/08/2022 09:01PM by Dust.
August 09, 2022 04:33AM
Dust
I'm not sure about the pinout, is it standardized or how else can I know it fits the one built in?
August 09, 2022 05:18AM
Its a standard foot print.
3 pins are encoder, 2 pins are switch, + 2 tabs to a fix it securely.
August 09, 2022 05:20AM
It also provides full dimensions on the page!
you just have to actually go look!
August 09, 2022 10:16AM
Dust
So I assume all the pins do the same as the ones on the original.
August 09, 2022 10:19AM
Dust
I've had a look at the website, but as I was afraid of choosing a part that has an incompatible pinout (not physically, in regards to what the pins function is) I chose to stay on the save side and ask if it's compatible.
Edited 1 time(s). Last edit at 08/09/2022 10:21AM by Das Sams.
