Easy Build for 300°C+?
Posted by aamcle
August 31, 2022 03:28PM
I have most of the parts I'd need to build another printer, I'd have to buy some rods and Z screws and probably set up an enclosure if the printer isn't enclosed
I want to be able to print PC so I need 300°C at the hotend possibly a little more but I don't think I would need a bed bigger than about 200x200mm.
What can you recommend as an accurate easy (1) build? Preferably one were I can just download the .stl files and print them.
A minor complication is that my extrusion is 3030 T slot not the more commonly used 2020.
Thanks All. aamcle
1 OK no build is easy so possibly 'less hard' smiling smiley
Edited 1 time(s). Last edit at 08/31/2022 04:41PM by aamcle.
Re: Easy Build for 300°C+?
September 01, 2022 04:33AM
I've found a number of small cubes but those that use extrusion use 2020 sad smiley and that would mean a lot of work.
aamcle
