A rebuildlog for a Delta printer February 14, 2023 02:40PM |
Re: A rebuildlog for a Delta printer February 16, 2023 09:23AM |
Re: A rebuildlog for a Delta printer February 16, 2023 01:20PM |
Re: A rebuildlog for a Delta printer February 16, 2023 02:42PM |
Re: A rebuildlog for a Delta printer February 17, 2023 02:28AM |
Re: A rebuildlog for a Delta printer February 17, 2023 06:41AM |
pi@miranda:~ $ dmesg | tail [ 18.092054] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 33.770401] cam-dummy-reg: disabling [ 48.040410] usb 1-1.4: new full-speed USB device number 5 using dwc_otg [ 48.195665] usb 1-1.4: New USB device found, idVendor=2341, idProduct=0042, bcdDevice= 0.01 [ 48.195714] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=220 [ 48.195733] usb 1-1.4: Manufacturer: Arduino (www.arduino.cc) [ 48.195748] usb 1-1.4: SerialNumber: 856323331363517080D0 [ 48.286835] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device [ 48.288644] usbcore: registered new interface driver cdc_acm [ 48.288668] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters/dev/ttyACM0 in both the flash command and the printer.cfg worked worked while /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_856323331363517080D0-if00 didn't
Re: A rebuildlog for a Delta printer February 17, 2023 10:07AM |
Re: A rebuildlog for a Delta printer February 17, 2023 11:22AM |
KERNEL=="ttyACM[0-9]*", SUBSYSTEM=="tty", ATTRS{idVendor}=="2341", ATTRS{idProduct}=="0042", SYMLINK="ttyP3D"
serial: /dev/ttyP3Dand this should return even if you unplug the Arduino then plug it back in.
serial: /dev/ttyACM0and it disconnects unexpectedly you could try simply unplugging the USB and plugging it back in.
Re: A rebuildlog for a Delta printer February 18, 2023 02:34PM |
Re: A rebuildlog for a Delta printer February 18, 2023 06:50PM |
Re: A rebuildlog for a Delta printer February 19, 2023 02:27PM |
Re: A rebuildlog for a Delta printer February 27, 2023 12:21PM |
Re: A rebuildlog for a Delta printer February 28, 2023 06:45PM |
Re: A rebuildlog for a Delta printer February 28, 2023 07:16PM |
Re: A rebuildlog for a Delta printer March 01, 2023 06:16AM |
Re: A rebuildlog for a Delta printer March 01, 2023 08:45AM |
leadinglights
....Another one is that selecting SD card on the LCD control panel results in the Pi freezing up.
Mike
Re: A rebuildlog for a Delta printer March 03, 2023 05:49AM |
Re: A rebuildlog for a Delta printer March 03, 2023 03:54PM |
Re: A rebuildlog for a Delta printer March 04, 2023 07:18AM |
Re: A rebuildlog for a Delta printer March 07, 2023 02:20AM |
Re: A rebuildlog for a Delta printer March 07, 2023 11:31AM |
Re: A rebuildlog for a Delta printer March 09, 2023 06:05AM |
max_z_velocity = 20is about, or even less than 20mm per second. If it is set higher than this, and I click "Home All" on mainsail, the mcu throws a spanner in the works with a message:-
Klipper reports: SHUTDOWN MCU 'mcu' shutdown: Rescheduled timer in the past This generally occurs when the micro-controller has been requested to step at a rate higher than it is capable of obtaining.
G0 Z0 F18000and it works without complaint but setting max_z_velocity to anything above 20 causes the above shutdown. This problem only appeared when I set micro-steps to 32 with the change of stepper driver modules to TMC2225.
Re: A rebuildlog for a Delta printer March 21, 2023 07:25AM |
Re: A rebuildlog for a Delta printer April 04, 2023 09:01AM |
Re: A rebuildlog for a Delta printer May 08, 2023 10:28AM |
Re: A rebuildlog for a Delta printer May 23, 2023 11:32AM |
Re: A rebuildlog for a Delta printer May 30, 2023 06:18AM |
Re: A rebuildlog for a Delta printer June 15, 2023 05:50AM |
Re: A rebuildlog for a Delta printer June 18, 2023 03:50PM |
Re: A rebuildlog for a Delta printer June 18, 2023 03:59PM |
