Help with Config Upgrade 1.21 -> 3.3 April 06, 2023 10:44AM |
Re: Help with Config Upgrade 1.21 -> 3.3 April 07, 2023 03:58AM |
M558 P9 H5 F120 T6000 ; Set Z probe type to bltouch and the dive height + speedsYou now have this one:
M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speedsYou need to change the probe type in this command from P1 to P9 as you had originally. You also need to use a M950 command to declare the pin you are using to control the BLTouch. See [docs.duet3d.com]. Finally, you will need to change the P parameter in the M208 commands you use in your deployprobe.g and retractprobe.g files to deploy and retract the pin, to match the logical port number that you created n the M950 command.
