Firmware Marlin-bugfix2.0.x-MKS-2.1.3
Posted by zarrefl
January 07, 2025 03:32PM
Hello, I recently purchased the MKS Robin Nano v3.1 + TMC2209 + WIFI + TS35 3D
My printer uses NO for endstop and the default setting is NC (normally closed) and the correct setting is NO (normally opened).
I looked for the default firmware to restore if necessary and found it only for Marlin-bugfix2.0.x-MKS-2.1.2.
Would anyone know the correct address?
open | download - Marlin-bugfix2.0.x-MKS-2.1.3.jpg (55.1 KB)
Re: Firmware Marlin-bugfix2.0.x-MKS-2.1.3
January 21, 2025 08:37PM
Hi, there really isn't this version available on github.
I had compilation problems in version bugfix2.0.x for USB_FLASH_DRIVE_SUPPORT configuration.
I solved it by modifying the code and then saw that this problem was resolved in the bugfix2.1.x version.
I have no hope of answers from MKS or that they will publish this version that came installed.
Edited 1 time(s). Last edit at 01/21/2025 08:39PM by zarrefl.
January 22, 2025 01:43AM
"and the correct setting is NO (normally opened)." no not really.
normally closed endstops are the standard, as it means that when you break a endstop wire (or unplug it) the endstop is triggered, vs just crashing the machine into the end of travel when the endstop is disconnected
Edited 2 time(s). Last edit at 01/22/2025 02:03AM by Dust.
January 22, 2025 01:52AM
It took me all of a minute of googling to find [github.com]
#define SHORT_BUILD_VERSION "-bugfix2.0.x-MKS-2.1.3"
from Version.h of [github.com]
Edited 1 time(s). Last edit at 01/22/2025 01:52AM by Dust.
