Pen Plotter Controller Options?
January 18, 2025 02:51PM
Hi all,
I'm working on a 3D printed pen plotter but I'm struggling to decide on which controller and firmware to use.
A while back I picked up an Uno, CNC shield and some tmc2208 drivers.
Most DIY pen plotters I've seen are running standard GRBL (CNC Mill) or LaserGRBL firmware.
Is there a GRBL based firmware that is specifically for pen plotters with a servo Z-axis?
I would really like it if the plotter could be run independently of a pc either via SD card or Wi-Fi, and had some sort of interface screen.
Is there a way I can do this with the Uno and CNC shield? Or do I need a more modern 32bit controller?
I noticed the Makerbase MKS DLC32, Could this be configured to have a servo z-axis?
Or am I better off forgetting about GRBL and going down the marlin and ramps route?
Sorry for so many questions! I find the CNC/laser controllers fairly confusing coming from the marlin world.
VDX
Re: Pen Plotter Controller Options?
January 18, 2025 03:23PM
... it's some (tens) years now, when I was last busy with controlling pen-plotters or similar -- last used Marlin4Due+Pronterface and RADDS (similar to RAMPS, but for the ArduinoDue)
Viktor
January 24, 2025 12:31PM
Hi VDX,
Sorry for the slow reply, I've been doing a bit of research into some of the options available.
I found one of the MKS DLC32 v2.1 boards on aliexpress for £7.50 with free shipping, I had to give it a try at that price! smiling smiley
The DLC32 has some really nice modern features:-
Wi-Fi and Bluetooth (can use phone or tablet for control)
A few different touchscreen options
3x Standard stepstick sockets (dip switches rather than jumpers)
32bit processor
Can run GRBL & LaserGRBL
SD card socket & Blade fuse for the PSU
I also ordered a nema8 stepper (20x20x34mm) for the Z-axis, hopefully it will be strong enough to actuate the pen.
Originally I was planning on using a servo to keep weight down but I think it would have been more trouble than its worth and a bit slow.
The design I'm working on slings the paper back and forth on the Y-axis just like a traditional drawing room pen plotter.
I need to find a way of sensing the leading or trailing edge of an A4 sheet of paper to be the Y-axis limit switch.
Do you know if those common optical end-stop's with a red PCB would trigger from a single sheet of paper?
Like this one:-
[ooznest.co.uk]
I fear the UV may pass straight through a single sheet but not too sure.
Can you think of a good way to sense the edge of an A4 sheet?
P.S. Should I use GRBL or laserGRBL for a pen plotter?
VDX
January 24, 2025 02:32PM
... AFAIK the LED's, used in this type of optical switches are IR, not UV ... but should be sensitive enough to get activated by a paper sheet.
Another methode, used for detecting paper on a black roll, is using reflexive optical sensors - here an amazon search:
[www.amazon.com]
LaserGRBL could be slightly easier, as a pen is something similar in use to a laser with the ON/OFF per line or polyline
Viktor
