GENERAL QUESTION May 10, 2026 06:37PM |
Re: GENERAL QUESTION May 11, 2026 03:24AM |
Admin Registered: 19 years ago Posts: 14,198 |
Re: GENERAL QUESTION May 11, 2026 03:54AM |
Admin Registered: 15 years ago Posts: 7,337 |
Re: GENERAL QUESTION May 11, 2026 09:12PM |
Re: GENERAL QUESTION May 11, 2026 10:39PM |
Re: GENERAL QUESTION May 11, 2026 11:23PM |
Re: GENERAL QUESTION May 11, 2026 11:46PM |
teps per unit:
ID settings:
rinter halted. kill() called!
D init fail
Re: GENERAL QUESTION May 11, 2026 11:55PM |
#define TEMP_1_PIN 14 // Analog Input #define TEMP_BED_PIN 15 // Analog Input
Re: GENERAL QUESTION May 12, 2026 12:51AM |
Re: GENERAL QUESTION May 12, 2026 09:20AM |
Re: GENERAL QUESTION May 13, 2026 12:33AM |
Re: GENERAL QUESTION June 21, 2026 10:20AM |
Re: GENERAL QUESTION June 21, 2026 11:24AM |
#elif MB(RADDS) #include "sam/pins_RADDS.h" // SAM3X8E env: DUE env: DUE_USBSo it uses build env DUE or DUE_USB
[env: DUE] platform = atmelsam #platform_packages = toolchain-gccarmnoneeabi@1.120301.0 # Otherwise it's GCC 7.2.1 board = due build_src_filter = ${common.default_src_filter} +<src/HAL/DUE> +<src/HAL/shared/backtrace>
+<src/HAL/DUE> tells marlin to build the code in that directory#elif defined(ARDUINO_ARCH_SAM) #define HAL_PATH(PATH, NAME) XSTR(PATH/HAL/DUE/NAME)
Re: GENERAL QUESTION June 21, 2026 11:58AM |
Re: GENERAL QUESTION June 22, 2026 09:59AM |
tring) [], CommandNotFoundException|
Re: GENERAL QUESTION June 22, 2026 11:40AM |
Re: GENERAL QUESTION June 22, 2026 02:00PM |
