Problems with extrusion July 08, 2011 08:21PM |
Re: Problems with extrusion July 08, 2011 09:34PM |
Re: Problems with extrusion July 09, 2011 12:33AM |
Anthong Redbeard
When you are in repsnapper can you get it to extrude at a rate you expect?
Make sure Dimension is enabled with add flowrate in skeinforge.
What material are you extruding and at what temp?
Verify your thermistor tyoe and that's the one you have set in the configuration.h firmware
Re: Problems with extrusion July 09, 2011 04:39PM |
Re: Problems with extrusion July 09, 2011 08:19PM |
Re: Problems with extrusion July 09, 2011 09:45PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: Problems with extrusion July 10, 2011 06:38PM |
Re: Problems with extrusion July 10, 2011 08:50PM |
Re: Problems with extrusion July 10, 2011 09:49PM |
Re: Problems with extrusion July 11, 2011 05:32AM |
Re: Problems with extrusion July 11, 2011 06:58AM |
Nophead
The steps per mm will be approximately micro steps per rev * gear ratio / ( pinch wheel diameter * pi).
For a Wades and x16 driver it would be 3200 * 39/11 / (5 * pi) = 722
Re: Problems with extrusion July 11, 2011 07:21AM |
Re: Problems with extrusion July 11, 2011 07:32AM |
Re: Problems with extrusion July 11, 2011 07:40AM |
Re: Problems with extrusion July 11, 2011 07:46AM |
Re: Problems with extrusion July 11, 2011 07:55AM |
Re: Problems with extrusion July 11, 2011 08:02AM |
Re: Problems with extrusion July 11, 2011 08:13AM |
Re: Problems with extrusion July 11, 2011 08:23AM |
Re: Problems with extrusion July 11, 2011 08:25AM |
Re: Problems with extrusion July 11, 2011 08:34AM |
Re: Problems with extrusion July 11, 2011 02:08PM |
Re: Problems with extrusion July 11, 2011 02:47PM |
Re: Problems with extrusion July 11, 2011 03:32PM |
Re: Problems with extrusion July 13, 2011 01:37PM |
Re: Problems with extrusion July 13, 2011 02:21PM |
Re: Problems with extrusion July 13, 2011 02:42PM |
Re: Problems with extrusion July 13, 2011 03:00PM |
Re: Problems with extrusion July 13, 2011 03:05PM |
Re: Problems with extrusion July 13, 2011 03:32PM |
