Nah. You can use chemistry to deposit a layer of metal on something.
An alternate approach to consider.
Instead of using Surface Mount devices, use the more traditional leaded variety.
Mount them back down, with the legs up, on flypaper, or a fitted tray, then pour your epoxy to cover the components, but not the leads. Shear off the leads where they protrude from the epoxy, wash, then plate the surface of the epoxy, (and the surface of the leads still visible as dots, or even very short risers.) Before plating, you could draw on the surface with a crayon equipped plotter to prevent those areas from being plated, or grind away the surface in much the way McMaster did with his original mill.
To add a second layer, do either of the following, (or both, but not recommended, for the sake of simplicity.)
A. Don't clip all the leads so short they'd be covered by a second layer of epoxy. Use the ones you don't clip short AS your risers. The drawback is now you need to be able to control how high an individual lead gets trimmed; you can't just mow them down to a common height.
B. Stick on risers between the plating stage and the second epoxy stage. The drawback here is now you need a separate tool to stick the risers in. Basically a wirefeed mechanism that can clip off a 1/4" length of wire after sticking it in mostly cured epoxy.
This way, you get the benefits of the described system, without having to actually drill so accurately as to touch a component without modifying either its resistance or its capacitance. You would get slightly larger finished products, however.
One thing to consider. If you can use pick-n-place capabilities to place your components, you can either use the same mechanism, with the addition of a wire-feed spool, to add risers, or you can use the same mechanism, with the addition of a pair of end cutting pliers beside the gripper tool.
Pouring the epoxy should be done from the side. Pour it so it covers the surface of the electronics like heavy objects left in a pool or tub when the water is turned on. The exposed surface should stay dry right up until the epoxy covers it.
Just an idea.
P.S. Depending on how soft the epoxy is, and how pliable the wire is, it should be possible to stick the protruding end of a wire off a spool into the soft epoxy, pull it out, (unwinding it, but not using a separate wire-feed motor,) and clip off the length that protrudes past the end of the clippers, (using the same gripper motor that places the circuits.)
The drawback of using the same motor for both operations is you eventually have to throw in another motor to raise the unused tool, so it doesn't interfere, or you're limited on how close you can pack the circuits; you wouldn't be able to place a circuit in a location that would interfere with depositing a riser, or you wouldn't be able to leave certain risers, as they intersected with the location of the grippers when the clippers were cutting a lead short elsewhere.
It might be possible to use your clippers as grippers, but I'd prefer to use a plunger mechanism for through-leaded components, as it'd orient the wires for us.
Take a piece of L-shaped channel, and cut a slot large enough to push a resistor through sideways, (if its leads were cut.) Attach your spool so it lines the components up with this hole. Now drop the mechanism to the board, and push a plunger through the slot, forcing the component out onto the board, (flypaper,) while also forcing the leads to bend upward to clear the channel. You'd still need some other mechanism for can-type capacitors, transistors, and DIP type components. Perhaps pliers that can be controlled to grip these, while still being strong enough to cut leads.
Then add a "wrist" actuator so you can remove one from play while using the other, (or a tool-change mechanism, which would actually be better.)
Edit 2, typo.
Edited 2 time(s). Last edit at 02/08/2008 06:12PM by Sean Roach.
