I've been experimenting a lot with SF41 recently and today I noticed that when the print is over instead of x and y going home the nozzle creeps away in a very slow shuddering motion. It must be the gcode, I've removed it from SF41's preface and it just stops (like you would expect.) But it seems any gcode I use causes the creep.
Here is the current end.gcode.
G91
G1 F70
G1 Z7 F70; lifts nozzle 7mm from finished print surface
G1 F2300
G1 X-200 F2300
G90
M104 S0; turns off extruder
And here is what the feed back says after the last line of useful code.
Received: Serial Error: LineNr is not the last line Nr+1
Received: Resend: 3844 with parameter 3844
SendData: N3844 M103 *26
SendData: N3845 G91 *43
Received: Huh? M103
Received: Resend: 3845 with parameter 3845
There a bit more. But I can concentrate on typing it all out right now.
Any help with this?
-John, San Diego, CA
www.youtube.com/user/GeoDroidJohn
MrJohnEcker on Twitter, Gmail
