Wildseyed simple hot end September 06, 2011 01:49PM |
You could almost certainly make the nozzle and block from aluminium rather than brass. But don't use two different metals: if you do thermal expansion will cause the heater block to work loose.
Re: Wildseyed simple hot end September 06, 2011 01:56PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Wildseyed simple hot end September 06, 2011 04:16PM |
Re: Wildseyed simple hot end September 07, 2011 10:19PM |
Re: Wildseyed simple hot end September 08, 2011 06:45AM |
Re: Wildseyed simple hot end September 10, 2011 04:30PM |
Re: Wildseyed simple hot end September 11, 2011 09:53AM |
Re: Wildseyed simple hot end September 14, 2011 10:19PM |
Re: Wildseyed simple hot end September 15, 2011 12:27AM |
