two repraps one computer
September 12, 2011 04:32PM
Can you run 2 repraps from one computer? I'm hoping you can by just opening repsnapper twice
__________________________________________________________________________
Experimenting in 3D in New Zealand
Re: two repraps one computer
September 12, 2011 11:44PM
HI..
Yes you can but you need diffrent dir for each repsnapper, so do, repsnapper1 and repsnapper2 and you should be right..
Auzze
September 13, 2011 05:12AM
I have done it with the one repsnapper installation. I have had 3 printers running at once.
September 13, 2011 06:22AM
are the repsnapper configurations identical except for comm port number used, or are they in different directories? are you using sd card or printing directly from host?
September 13, 2011 07:28AM
I was only using repsnapper to sent the gcode. I generate the gcode using skeinforge. The only thing I had to change in repsnapper was the port number.
September 13, 2011 03:49PM
Thanks guys, should be all good to go as soonvas the build is finished then
