Problem importing OpenSCAD STL in HeeksCAD
Posted by devijvers
September 19, 2011 01:28PM
Every STL produced by OpenScad I try to import in HeeksCAD results in the same result: either it doesn't display or I get artifacts. Other STLs work fine. What am I doing wrong?
My own objects don't work and neither do other people's objects. I tried to import the STLs for Prusa part and they give the same behavior. I'm using HeeksCAD 0.18.0.
Re: Problem importing OpenSCAD STL in HeeksCAD
September 20, 2011 06:21AM
I can't import OpenScad stls anywhere too. The only program that accepts them is Blender, so I import stl to Blender, then export, and exported stl can be used anywhere.
September 20, 2011 06:58AM
DeltaFlight
@DeltaFlight thanks for the tip, I'll give this a try.
