I think 1.75 allows for two benefits: 1) finer control of the extruded plastic amount and 2) you can build a smaller and lighter extruder so your x-axis will have less chance backlash issues at higher speeds.
Mendel's are usually 20x20 cm, I am building a Prusa Mendel myself.
The yellow film is Kapton tape. It's a heat resistent tape and works really well as a print surface. If you use a heated bed (PC
, you may not need the aluminum plate. I'll be applying the tape directly to the PCB and printing on that. I'm ordering my tape from Amazon.
If you don't have a heated bed, you'll have more issues with larger prints warping as the lower layers cool.
I'm a noob myself, so if anyone sees something wrong, please call it out.
Edited 1 time(s). Last edit at 09/20/2011 09:29PM by hardtoe.
