Hello,
noob questions about the printing, could not find answers elsewhere:
a) if a part is prepared out of PLA or ABS, will it remain stable at hot bathroom water temperatures (50-60 C; 140 F)? Or will parts soften up and begin to move?
b) What is the resolution possible to achieve with a Prusa? I see a 1.75 mm print head, so I assume that the molten plastic will be of that order, but is that the limiting factor, or more related to the mechanical resolution of the drive system?
For instance, is it possible to print 1 mm diameter holes in a part?
c) finally, about how long does it take to print a part; lets say a square box, 2.5 cm on a side, 1 cm high with a 3 mm thick wall? Just trying to get an idea of how quick the process might be, just have no feel for this.
Thanks very much!
