Re: Building a RepRap in ZA June 02, 2012 07:20AM |
Re: Building a RepRap in ZA, Pretoria/ Joburg area June 17, 2012 03:04AM |
Re: Building a RepRap in ZA August 13, 2012 07:25AM |
Re: Building a RepRap in ZA October 01, 2012 02:10PM |
Re: Building a RepRap in ZA October 23, 2012 09:58AM |
Re: Building a RepRap in ZA October 23, 2012 10:52AM |
Re: Building a RepRap in ZA January 17, 2013 10:45AM |
Re: Building a RepRap in ZA January 18, 2013 01:40AM |
Re: Building a RepRap in ZA March 05, 2013 04:52PM |
Filament in South Africa April 06, 2013 06:53AM |
Re: Building a RepRap in ZA April 06, 2013 07:02AM |
Re: Building a RepRap in ZA April 17, 2013 08:59AM |
Re: Building a RepRap in ZA April 18, 2013 02:49AM |
Re: Building a RepRap in ZA September 23, 2013 06:11PM |
Re: Building a RepRap in ZA January 29, 2014 08:00AM |
Re: Building a RepRap in ZA March 18, 2014 06:17PM |
Re: Building a RepRap in ZA April 28, 2015 11:38AM |
Re: Building a RepRap in ZA April 28, 2015 01:44PM |
Re: Building a RepRap in ZA April 08, 2016 04:15AM |
Re: Building a RepRap in ZA April 08, 2016 04:34AM |
Re: Building a RepRap in ZA April 10, 2016 07:18AM |
Re: Building a RepRap in ZA April 16, 2016 06:13AM |
JohnPowell
Hi Skillet
I have built a Prusa i3 from a kit and been involved in a second one and rebuilt mine and taking it further as well
Also a little Hurricane from NetRam here in Cape Town
If you haven't already done so I suggest you visit Netram behind Century City and speak to anyone there (Tell them I referred you - John Powell)
I am currently very tight for time myself but in due course like to join any groups that meet
Good Luck
Re: Building a RepRap in ZA April 16, 2016 06:25AM |
RiaanLR
Hi and welcome.
First decide on what you will be printing the most. ABS(hot) or PLA(colder). I think you should build the kit to suite your needs. If printing more ABS you will for sure need an enclosure to get better prints. For PLA again colder room temp will be better. And so does the hot ends then also play a role.
My machine is setup for ABS and i struggle with PLA so i now want to build a delta machine for that.
The one refer to is a good starting point if you want to start with 3d printing. You will want to do some upgrades later. But for learning the basics its fine. I will however not put the perspex frame in an enclosure. Thats why i went for the P3steel. I had the frame laser cut locally in Paarl and bought most components local. I made a copy of the E3D hot end and works great for ABS. That's if you have access to a lathe.
You will find all sorts of stepping stones along the way. But that only makes it nicer and sometimes just"urgggggg".
So there are local help if you need.
Riaan
Re: Building a RepRap in ZA April 18, 2016 12:23PM |
Re: Building a RepRap in ZA April 26, 2016 05:43AM |
Re: Building a RepRap in ZA April 27, 2016 01:12AM |
Re: Building a RepRap in ZA May 15, 2016 06:11PM |
