my first reprap November 22, 2013 02:20AM |
Re: my first reprap November 26, 2013 02:39AM |
Re: my first reprap November 26, 2013 03:39PM |
Moderator Registered: 10 years ago Posts: 126 |
Re: my first reprap December 02, 2013 06:58PM |
Re: my first reprap December 03, 2013 11:23PM |
Re: my first reprap December 26, 2013 12:05AM |
Re: my first reprap December 27, 2013 04:50AM |
sdavi
I.e. Does it make grinding noises? Shredding filament? Not moving at all etc Have you set the correct ESteps yet? Are you using the correct temperature for the filament ?
I would suggest ruling out each part one by one.
Remove hobbed bolt and hotend, and check if filament can move through the extruder block hole by hand and there are no blockages.
Check the hobbed bolt and make sure the groove is even and make sure the groove lines up with the filament hole in extruder. With the hotend still removed see if you turn the gears the filament can go through
Heat up the hotend and see if it reaches temperature.
Heat up the hotend and choose to extrude say 10mm without any filament loaded and check that the hobbed bolt is actually rotating, and in the correct direction.
Re: my first reprap January 03, 2014 02:02AM |
Re: my first reprap January 21, 2014 06:49PM |
Re: my first reprap February 10, 2014 12:25AM |
