Construction de ma Prusa V2 January 26, 2012 07:50PM |
#define STEPS_PER_M_Z 1280000Réglage impeccable (mesure au pied à coulisse de l'écart entre le plateau et une barre de l'axe X après un déplacement de +10 mm dans Printrun (via l'interface Pronterface).
#define STEPS_PER_M_X 80000 #define STEPS_PER_M_Y 80000 #define STEPS_PER_M_Z 1280000 #define STEPS_PER_M_E 682000 // ligne ci-dessous décommentée #define E_ABSOLUTE
Slic3r/bin/slic3r $s --load Slic3r/config.ini --output $osliceoptscommand :
Slic3r/bin/slic3r --load Slic3r/config.ini --ignore-nonexistent-configVoici après des essais, le fichier config.ini de Slic3r permettant d'obtenir à partir d'un fichier .stl un fichier au format Gcode qui conviennent à ma machine pour extruder du PLA (T° Extrudeur 190°C) :
bottom_layer_speed_ratio = 0.35 bridge_flow_ratio = 1 bridge_speed = 50 duplicate_distance = 6 duplicate_x = 1 duplicate_y = 1 end_gcode = G28 X0 ; home X axis\nM104 S0 ; make sure the extuder is turned off.\nM140 S0 ; make sure the bed is turned off.\nM84 ; disable motors extrusion_axis = E extrusion_multiplier = 1 extrusion_width_ratio = 0 filament_diameter = 2.80 fill_angle = 45 fill_density = 0.4 fill_pattern = rectilinear first_layer_height_ratio = 1 g0 = 0 gcode_arcs = 0 gcode_comments = 1 infill_every_layers = 1 infill_speed = 60 layer_height = 0.3 nozzle_diameter = 0.4 output_filename_format = [input_filename_base].gcode perimeter_speed = 60 perimeters = 3 print_center = 100,95 retract_before_travel = 2 retract_length = 1 retract_lift = 0 retract_restart_extra = 0 retract_speed = 20 rotate = 0 scale = 1 skirt_distance = 6 skirt_height = 1 skirts = 1 small_perimeter_speed = 50 solid_fill_pattern = rectilinear solid_infill_speed = 60 solid_layers = 3 start_gcode = G28 ; home all axes\nG92 E0 ;reset extruder\nG1 E3 F1200 ;Prime extruder 3mm\nG1 E2 F1200 ;retract extruder 1mm\nG92 E0 ;reset extruder temperature = 190 travel_speed = 130 use_relative_e_distances = 0 z_offset = 0
Re: Construction de ma Prusa V2 January 27, 2012 01:12AM |
Re: Construction de ma Prusa V2 January 27, 2012 02:09AM |
Re: Construction de ma Prusa V2 January 31, 2012 07:08AM |
Re: Construction de ma Prusa V2 January 31, 2012 07:57AM |
Re: Construction de ma Prusa V2 January 31, 2012 09:11AM |
Re: Construction de ma Prusa V2 January 31, 2012 09:39AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Construction de ma Prusa V2 January 31, 2012 03:33PM |
Re: Construction de ma Prusa V2 February 01, 2012 06:51AM |
Re: Construction de ma Prusa V2 February 01, 2012 01:05PM |
Re: Construction de ma Prusa V2 February 02, 2012 06:01AM |
Re: Construction de ma Prusa V2 February 05, 2012 11:49AM |
Re: Construction de ma Prusa V2 February 19, 2012 07:15PM |
Re: Construction de ma Prusa V2 February 20, 2012 02:54AM |
Re: Construction de ma Prusa V2 February 20, 2012 05:00PM |
Re: Construction de ma Prusa V2 February 20, 2012 06:18PM |
Re: Construction de ma Prusa V2 February 21, 2012 05:06PM |
Re: Construction de ma Prusa V2 February 21, 2012 06:26PM |
Re: Construction de ma Prusa V2 February 22, 2012 04:52PM |
Re: Construction de ma Prusa V2 February 29, 2012 07:08AM |
Re: Construction de ma Prusa V2 February 29, 2012 08:07AM |
Re: Construction de ma Prusa V2 February 29, 2012 08:35AM |
Re: Construction de ma Prusa V2 February 29, 2012 04:56PM |
Re: Construction de ma Prusa V2 February 29, 2012 05:35PM |
Re: Construction de ma Prusa V2 March 01, 2012 02:16AM |
Re: Construction de ma Prusa V2 March 01, 2012 02:30AM |
Re: Construction de ma Prusa V2 March 01, 2012 02:42AM |
Re: Construction de ma Prusa V2 March 01, 2012 05:53PM |
Re: Construction de ma Prusa V2 March 03, 2012 11:55AM |
Re: Construction de ma Prusa V2 March 03, 2012 12:58PM |
