Premiers cris de ma pursa April 08, 2012 12:00PM |
Re: Premiers cris de ma pursa April 08, 2012 04:04PM |
Re: Premiers cris de ma pursa April 08, 2012 06:28PM |
Re: Premiers cris de ma pursa April 09, 2012 05:04AM |
Re: Premiers cris de ma pursa April 09, 2012 08:35AM |
Re: Premiers cris de ma pursa April 09, 2012 02:43PM |
Re: Premiers cris de ma pursa April 09, 2012 03:04PM |
Re: Premiers cris de ma pursa May 05, 2012 07:52AM |
/***************************************************************************\ * * * 4. TEMPERATURE SENSORS * * * \***************************************************************************/ /** TEMP_HYSTERESIS: actual temperature must be target +/- hysteresis before target temperature can be achieved. Unit is degree Celsius. */ #define TEMP_HYSTERESIS 20 /** TEMP_RESIDENCY_TIME: actual temperature must be close to target for this long before target is achieved temperature is "achieved" for purposes of M109 and friends when actual temperature is within [hysteresis] of target for [residency] seconds */ #define TEMP_RESIDENCY_TIME 60 /// which temperature sensors are you using? List every type of sensor you use here once, to enable the appropriate code. Intercom is the gen3-style separate extruder board. // #define TEMP_MAX6675 #define TEMP_THERMISTOR // #define TEMP_AD595 // #define TEMP_PT100 // #define TEMP_INTERCOM // #define TEMP_NONE /***************************************************************************\ * * * Define your temperature sensors here. One line for each sensor, only * * limited by the number of available ATmega pins. * * * * For a GEN3 set temp_type to TT_INTERCOM and temp_pin to 0. * * * * Types are same as TEMP_ list above - TT_MAX6675, TT_THERMISTOR, TT_AD595, * * TT_PT100, TT_INTERCOM, TT_NONE. See list in temp.c. * * * * The "additional" field is used for TT_THERMISTOR only. It defines the * * name of the table(s) in ThermistorTable.h to use. Typically, this is * * THERMISTOR_EXTRUDER for the first or only table, or THERMISTOR_BED for * * the second table. See also early in ThermistorTable.{single|double}.h. * * * \***************************************************************************/ #ifndef DEFINE_TEMP_SENSOR #define DEFINE_TEMP_SENSOR(...) #endif // name type pin additional DEFINE_TEMP_SENSOR(extruder, TT_THERMISTOR, PINA1, THERMISTOR_EXTRUDER) DEFINE_TEMP_SENSOR(bed, TT_THERMISTOR, PINA2, THERMISTOR_BED)Edit : J'ai aussi un problème avec les fins de cours (opto), quand ils s'enclenchent, la led s'allume, mais le déplacement continu... Je dois aussi configurer quelque chose ?
Re: Premiers cris de ma pursa May 09, 2012 07:39AM |
// ./createTemperatureLookup.py --r0=100000 --t0=25 --r1=0 --r2=4700 --beta=4066 --max-adc=1023 // r0: 100000 // t0: 25 // r1: 0 // r2: 4700 // beta: 4066 // max adc: 1023Après ça je passe à la calibration.
